1990 Montero blew headgasket ...
#1076857
02/20/15 04:56 AM
So now I am trying to figure out what to do. Rebuild the engine with well over 300,000 miles. Somebody offered a block with 180k. that I would to go home to PA to get. My truck was running fine. Oil is OK. Runs except on 1 cylinder down and smokes like a fog machine.
Re: 1990 Montero blew headgasket ...
[Re: sasnydley]
#1076858
02/20/15 08:50 AM
find out whats up with the dead cylinder
1990 LWB RS A/T 1990 LWB Base A/T 1991 LWB LS A/T Going...Going...
[Re: danz91crx]
#1076859
02/20/15 04:02 PM
Do a compression test on the motor to see what the other cylinders are like ... The V6 12 valve motor do go a long time ..
[Re: haztoys]
#1076860
02/20/15 05:18 PM
I Think you should take Rich up on that engine, overhaul it, then swap it back in to get another 200k out of your gorgeous rig.
[Re: Jay Ayala]
#1076861
02/21/15 04:06 AM
I am planing on doing just that. If I had some extra mula to blow I would be getting a diesel package to swap out.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6040 MB (Peak: 0.6679 MB) Data Comp: Off Server Time: 2026-10-24 23:55:41 UTCValid HTML 5 and Valid CSS
