Page 2 of 4 1 2 3 4
Re: Another source for 3.5 DOHC Parts [Re: haztoys] #1076990 02/28/15 11:26 PM
justice Offline OP
Interesting. Would be great to have options since rebuilds never seem to work out.
Please stop saying the 3.5 'can't' be reman and stop the rumors ... Its BS and your wrong....
I did a part number look and 'nothing' crosses over to a SR from this motor ... Not even the crank ... The crank list the Monty sport ,,,Monty ,,, and cars... But thats it ...???????
Not trying to be a horses a$$ just want facts ...
Have a good day
Captain Gear Box
Hazardous Toys inc
I seen one site where the the head kit to include the valves was a cross over. also same head bolts..that still leaves a lot of variables though.
Re: Another source for 3.5 DOHC Parts [Re: justice] #1076991 03/01/15 05:31 AM
justice Offline OP
Pics to compare. I could not find any visible differences EDIT scratch that..after further review, heads appear identical. Block very similar but water pump inlet and outlet closer together. timing belt tensioner looks the same but mounted at a more upward angle. timing belt pulleys both look identical. oil pump pick up on other side so oil pump not same.
In short. Same heads but small differences in block.
bottom line, its probably a good source for used heads and lower and middle intake (dreaded butterflies). worth further looking into.
http://engineguy.com/1996-94-mitsubishi-3-5-l-engine-6g74-atk251-vin-m.html
http://engineguy.com/05-03-kia-3-5-l-6-cyl-engine-g6cu-35d-atk261a-vin.html
The kia guy that came in here originally stating this was laughed out of here. But I think he was mostly right. Same heads and the block is very close.
Re: Another source for 3.5 DOHC Parts [Re: justice] #1076992 03/01/15 07:14 AM
Would be great if that works. The butterflies and vss are all that is wrong with the one on my engine stand
Re: Another source for 3.5 DOHC Parts [Re: Mudraider] #1076993 03/01/15 04:12 PM
Lloyd Swartz Offline
BTW when looking at even newer engines the butterfly's make re-appearances and fail in the same manner, as late as the last few years. So you always have to watch out for those on Mits motors as well.
Re: Another source for 3.5 DOHC Parts [Re: Lloyd Swartz] #1076994 03/02/15 03:51 AM
Have a couple jy that I deliver to for work, can probly get one n/c for experimenting/inspection purposes. Now only if they have them.
Re: Another source for 3.5 DOHC Parts [Re: Mudraider] #1076995 03/02/15 02:58 PM
03 Sorrento. Owner wasn't there, talked to my contact, we'll see what I can get the longblock for. Hopefully the engine is bad.
Re: Another source for 3.5 DOHC Parts [Re: justice] #1076996 03/02/15 03:24 PM
P
pondraider Offline
When comparing the engine pics on engineguy.com to other Mitsubishi 3.5l the differences in the Kia engine block are similar to the newer SOHC 3.5l blocks. The angle of the timing belt tensioner appears to be the same to the tensioner angle in my 2000 3.5. Also the oil filter is on the same side as the 2000 3.5 block.
It very well could be the Kia/Hyundai DOHC 3.5l has the same heads and intake as the 94-96 Mitsu DOHC 3.5l and the Kia block is the same as the 97-00 Mitsu SOHC 3.5l.
'87 Raider "LandRaider"
'89 Montero LWB V6 Auto Dual Bouncy LSD
'89 Raider SWB V6 Manual Dual Bouncy
'95 LS Manual Stock
'00 Endeavor
'03 Limited
Re: Another source for 3.5 DOHC Parts [Re: pondraider] #1076997 03/02/15 07:30 PM
That is making me feel better. The idea of spending $400-$500 on something I can't use has bothered me. The idea that I can freshen up my 94 SR 3.5 engine with some newer parts is appealing. But still a crap shoot.
Re: Another source for 3.5 DOHC Parts [Re: Mudraider] #1076998 03/03/15 01:09 AM
Sounds like your the Guinea Pig, someone has to be <img src="/forums/images/graemlins/oink.gif" alt="" /> <img src="/forums/images/graemlins/oink.gif" alt="" />
Re: Another source for 3.5 DOHC Parts [Re: Lloyd Swartz] #1076999 03/03/15 04:13 AM
Going to try Lloyd, going to try
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6454 MB (Peak: 0.7685 MB) Data Comp: Off Server Time: 2026-06-07 08:27:28 UTC
