MORE STUFF LISTED!! Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts #1077012 03/01/15 03:47 PM
W
willwinchforfood Offline OP
HELP ME PAY FOR MY MASTERS DEGREE.
PM me your cell phone number if you want pics.
Sold LSD Out of 88/89 Starquest.
Water pump for 6g72 P/N 42162 new in box with gasket. Napa brand. $15 plus shipping or offers.
M5269L chip drivers for V6 gen 1 ECU. I'll send these to you for the cost of a few stamps. You must demonstrate to me you know what these are for and that you have soldering experience. I don't want them sitting on a shelf forever.
Sold Genuine Safari Snorkel
Sold Surco 50x60 rack
Left and right Hubs off of Gen 2. Use to convert your Gen 1 4 cylinder to bigger SR brakes. As far as I can tell get new bearings and bolt them on. 50 or offers plus shipping. Kinda heavy. Can fit in a usps flat rate box I think. If you wait on this one, I may have rotors calipers and caliper mounts. I need to find them.
4 cylinder valve cover gasket kit fel pro vs 50146R. 5 bucks.
4 cylinder timing cover set fel pro tcs 45750. Box was bent. 5 bucks
4 cylinder weber carb snorkel adapter. Read about this one. Takes some work to get it to fit. 125 plus shipping or offers.
3.0 throttle body with 89 preheater and new throttle body to intake gasket. Missing IAC. 50 or offers plus shipping.
Rings that hold on plastic hub covers. Rings broken in one spot. Still work. Free if you pay shipping.
Gen 1 auto hubs. 10 plus shipping. Worked when pulled.
3.0 alternator bracket. 10 plus shipping
3.0 outboard support bracket for the intake. The one that's hard to get to between the firewall and intake. 5 plus shipping.
Alternator off of maybe a Diamante? Only numbers I can find are AB111057. I think this is a higher amp alternator that can fit on the 4 cyl. Make an offer. A cheap offer. Seriously it's ok to make an insulting offer.
3.0 fuel rail. Maybe 4 good injectors. Harness with plug. Fuel pressure regulator. 20 plus shipping.
Gen 2 bolt on upper ball joint. No box. I think Duralast brand. 5 plus shipping.
Outboard plenum support for 3.0. Bolt to left side forward if I remember correctly. 5 plus shipping.
Will trade combination of above for a Corp 14 bolt Chevy axle with 3.42 ratio (this ratio is kin to a magical unicorn fart) in good useable condition. Will travel to bordering states for pickup halfway.
Located in Atlanta Ga area. 30084 zip code
I'll be posting all of my Montero parts as I clean them out. Keep watching for updates. Ask me if you need something. I might have it. Also if you are hard up on cash and really need a mechanical (something to keep your truck on the road, not make it look awesome) part I have listed, I'm flexible on pricing for you. I know how it is brothers and sisters!
Re: Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts [Re: willwinchforfood] #1077013 03/02/15 02:34 AM
Why a 3.42? That is just so odd for a truck or Suburban, more typical in the car 10-bolt. Are you using this in a diesel?
Re: Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts [Re: willwinchforfood] #1077014 03/02/15 06:41 PM
P
pondraider Offline
pm sent
'87 Raider "LandRaider"
'89 Montero LWB V6 Auto Dual Bouncy LSD
'89 Raider SWB V6 Manual Dual Bouncy
'95 LS Manual Stock
'00 Endeavor
'03 Limited
Re: Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts [Re: pondraider] #1077015 03/03/15 07:53 PM
MI_Mitsu Offline
pm sent
hey pondraider, not sure what youre interested in here on his list, but I have a passing interest as well. My problem is my location. I seen from your sig you spend 1/2 your time up here in Michigan as well, if youre planning a drive by to pick-up some of these items, do you think you'll be driving through SE Michigan in the next several weeks and you could drop off some things for me? Maybe together we could help out willwinch with his school fund!
Jim
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts [Re: rxinhed] #1077016 03/07/15 03:25 AM
W
I have 3.42 in the front. I like it on the highway. Fine off-road too.
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts [Re: willwinchforfood] #1077017 03/07/15 05:10 AM
Try car-part.com? There are numerous GU6 code axles for you.
Re: Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts [Re: rxinhed] #1077018 03/08/15 01:02 AM
W
Son of a ... I forget about that site.
Re: Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts [Re: willwinchforfood] #1077019 03/09/15 05:06 AM
BottomFeeder Offline
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts [Re: BottomFeeder] #1077020 03/09/15 05:28 AM
But it's a 1/2-ton with a 12 bolt Corporate rear axle, not the 14-bolt.
Re: Starquest LSD, water pump, electronics. Cleaning out my Mitsubishi parts [Re: rxinhed] #1077021 03/10/15 02:22 AM
W
And half a country away but thanks for the link.
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6343 MB (Peak: 0.7435 MB) Data Comp: Off Server Time: 2026-07-09 16:46:09 UTC
