Im doing SAS and Doublers on my 2.5gen. Check it out #1077042 03/04/15 06:47 AM
E
eurosonic Offline OP
Re: Im doing SAS and Doublers on my 2.5gen. Check it out [Re: eurosonic] #1077043 03/04/15 08:43 AM
Ian Sharpe Offline
well done mate, I'm doing the same but I'm using the Behemoth strong box in front of a NV 242, that way I keep the select trac.
I found that I can use the pajero pulse wheel but just had to grind a bit off the inside of the Jeep tailhousing so that it
can turn freely.
I'm just waiting on a speedo convertor from Summit Racing.
I used twin shifters from Behemoth, they fit nicely where the Pajero 4x4 shifter is. there is no hacking of the console either.
I'll post up pics when its done, cheers
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
Re: Im doing SAS and Doublers on my 2.5gen. Check it out [Re: Ian Sharpe] #1077044 03/04/15 06:47 PM
E
thats awesome. I was thinking about a 242 but I really see no use for select trac for trails around my neck of the woods.
Ill still need to study on how to do the speedo conversion. Will be using a Dakota Digital?
Re: Im doing SAS and Doublers on my 2.5gen. Check it out [Re: eurosonic] #1077045 03/04/15 08:53 PM
Ian Sharpe Offline
yes, I am getting the SGI-5
http://www.dakotadigital.com/index.cfm/p...prod/prd126.htm
Theres also Nathans write up here: The pics are gone but the text is still good, its a good read,
http://www.4x4wire.com/forums/showf...mp;page=0&fpart=all&vc=1
Re: Im doing SAS and Doublers on my 2.5gen. Check it out [Re: Ian Sharpe] #1077046 03/06/15 05:10 AM
leadheavy52 Offline
Awesome build. Its inspiring. I've been on the fence about parking mine and tearing into her and making her into the truck I've always wanted her to be. An overland exploration vehicle suited for long ventures into the wilderness. Right now, with 192 k on the clock and an ever growing laundry list of "fix me's", I can not say she's ever let me down on the road and never not tackled any off-road challenge I myself did not have the guts for. This is my second Montero, following an '88 SWB. A growing family forced me to sell that one. If I don't keep my 97 LS, then maybe a '90 LWB with a turbo diesel swap would be ideal. While I do push my truck off-road, and will admit the IFS set up, the cost and labor involved far outweigh the benefit for the suspension alone. Well done however with your modifications. It's always nice to see these great trucks get the love they deserve.
Also, I have decided that if Mitsubishi decides to bring the Montero back to the U.S. in 2017, they better consult this board first!
1988 SWB Montero - 2.6L - 5-speed
Weber Carb
(Coming Soon) Rugged Ridge AVM Hubs
Re: Im doing SAS and Doublers on my 2.5gen. Check it out [Re: leadheavy52] #1077047 03/07/15 05:02 AM
Have you considered a Dana 50 front axle from a late model F250? Pair that with a rear Stirling axle and retain your 4-wheel disk brakes.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6116 MB (Peak: 0.6838 MB) Data Comp: Off Server Time: 2026-07-15 17:31:30 UTC
