Side mirrors #1077048 03/05/15 02:41 AM
Raider17 Offline OP
I'm in need of some new side mirrors for my 89 raider. I currently have the single point anchor with the two screw holes into the exterior door panel. Just checking to see if someone might have a set on a spare rig or know of some good universal ones. The universals I've come across, I haven't been impressed with.
89 Raider 2.6/38 Weber/2" lift/32x11.50/9.5k smitty built/custom bumpers/roof rack
Re: Side mirrors [Re: Raider17] #1077049 03/05/15 04:32 AM
Toyota pickups of the same era have similar mirrors to the upscale Montero pieces. Also, PeteD successfully installed late model Wrangler mirrors on his flying tomato Raider a few years ago.
Re: Side mirrors [Re: rxinhed] #1077050 03/07/15 12:24 AM
Raider17 Offline OP
I'll Keep looking, thanks!
Re: Side mirrors [Re: Raider17] #1077051 03/18/15 10:13 PM
MI_Mitsu Offline
Ive always wanted to try these aftermarket pieces from Rugged Ridge. here in the Midwest, I liked the idea of adding heated side mirrors. Especially handy 1/2 of the year here!
Rugged Ridge side mirrors w/ LED marker lamps and heat!
But if you like the looks of stock/factory - I have about 12 spare mirrors, nearly all the larger dual-mount LS style.
Jim
Re: Side mirrors [Re: MI_Mitsu] #1077052 03/20/15 03:39 AM
heathdogg Offline
12 spare? I've been looking for a set to get rid off the crappy little mirrors on my raider.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Side mirrors [Re: MI_Mitsu] #1077053 03/25/15 12:17 AM
Raider17 Offline OP
Those rugged ridge one's were pretty nice but kinda pricey. I found a set on an 80's toyota what are collapsible. They had the rubber seal and all the glass. $40, I was able to use the forward most existing hole, drill a second and use the oem screws. Looks good to me! If I can figure out how to post pictures I'll put one on in case anyone else runs into that issue in the future.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6108 MB (Peak: 0.6808 MB) Data Comp: Off Server Time: 2026-05-29 17:54:00 UTC
