'87 Gen 1 swb 2.6L, manual trans. Can't find Haynes manual. Need some info. #1077190 03/11/15 01:55 AM
TresMon Offline OP
I rebuilt my 2.6L less than 10k miles ago. Recently started burning coolant.
Yanked the ( brand new improved casting complete) head off. Have the head at the engine shop checking for warpage or cracks.
The (solid annealed copper ) head gasket is fine. Number two piston top looks steam cleaned compared to the rest. I noticed that the inner most head bolts were noticeable looser than the outer head bolts, despite a torque, and a re-tourque 300 miles later. I'm sure thats my problem, as the engine again is a fresh rebuild and has fresh new 50/50 coolant in it. Sure nothing froze.
Tomorrow or the next day I will be putting the head back on and buttoning things up. But I can't find My Hane's manual for the truck regarding sticking the distributor back in timing it and all that...
So need the reference: what is the spec/sequence on putting the distributor back in the head?
Front piston at TDC, what valve(?) or both valves closed? or?
Rotor in distributor pointing it at what plug? front piston??
Which socket in the distributor cap goes to what piston? (firing order?)
Thanks so much. Cant find my book anywhere and none of the stores around me have one on the shelf.
Tres
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: '87 Gen 1 swb 2.6L, manual trans. Can't find Haynes manual. Need some info. [Re: TresMon] #1077191 03/11/15 02:39 AM
W
willwinchforfood Offline
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: '87 Gen 1 swb 2.6L, manual trans. Can't find Haynes manual. Need some info. [Re: TresMon] #1077192 03/11/15 05:37 AM
mag00 Offline
#1 to TDC (of the compression stroke). Insert distributer, line up the marks, and position rotor to the #1 spark plug position on the cap.
http://zywie.com
Zywie's Law: If anything can go right, it will go right, and at the best possible time.
Re: '87 Gen 1 swb 2.6L, manual trans. Can't find Haynes manual. Need some info. [Re: mag00] #1077193 03/11/15 05:18 PM
TresMon Offline OP
Thanks!
What is the firing order?-- which plug position on the distributor cap goes to what cyl?
What are the head bolt torque spec?
Thanks!
Mitsubishilinks.com will not load for me. <img src="/forums/images/graemlins/scared.gif" alt="" />
EDIT: was able to get the Haynes manual file to finally open on mitsu links. Thanks.
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: '87 Gen 1 swb 2.6L, manual trans. Can't find Haynes manual. Need some info. [Re: TresMon] #1077194 03/12/15 02:43 AM
PM me an offboard email address and I'll forward the 2.6L FSM section. Burn the Haynes manual.
Re: '87 Gen 1 swb 2.6L, manual trans. Can't find Haynes manual. Need some info. [Re: TresMon] #1077195 03/12/15 05:12 AM
if you can find some nuts that fit your head bolts, you may want to put them on, thread them up to the top of the threads. If you have a die, put that on next, then grind the last couple threads off to shorten the bolt a bit.We used to do this on VW motors that we cut down for compression. Then run the die off, and then the nuts. That should give you clean threads, and hopefully alleviate the possibility that the head bolts are bottoming out before they get to full torque. It might help
Re: '87 Gen 1 swb 2.6L, manual trans. Can't find Haynes manual. Need some info. [Re: Mudraider] #1077196 03/12/15 05:55 AM
Better than head bolts, get some ARP studs...
Re: '87 Gen 1 swb 2.6L, manual trans. Can't find Haynes manual. Need some info. [Re: rxinhed] #1077197 03/12/15 09:18 AM
Heck yeah, if they make then that would be the ideal thing to have
Re: '87 Gen 1 swb 2.6L, manual trans. Can't find Haynes manual. Need some info. [Re: Mudraider] #1077198 03/15/15 02:26 PM
plh Offline
ARP does make them. I had a set for a while, but sold them a couple years ago.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6330 MB (Peak: 0.7378 MB) Data Comp: Off Server Time: 2026-05-27 21:18:29 UTC
