InStant fill gas cap #1077213 03/13/15 06:39 PM
87Montero Offline OP
My gas cap is worn out, so I want to replace it with one of these because I am lazy and used to the Ford rental cars lately. <img src="/forums/images/graemlins/wink.gif" alt="" />
Has anyone had success finding on that fits?
I found a listing for one for a 2000 Montero sport, and I thought those used the same cap?
Re: InStant fill gas cap [Re: 87Montero] #1077214 03/15/15 05:16 AM
Lloyd Swartz Offline
I like it. Let us know what you find.
Re: InStant fill gas cap [Re: 87Montero] #1077215 03/17/15 03:28 AM
zarktheshark Offline
I looked at these awhile back but never pulled the trigger. I found it on amazon
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: InStant fill gas cap [Re: zarktheshark] #1077216 03/17/15 11:46 AM
haztoys Offline
Did you read the reviews ...? More upset then happy ... If your car sniffs the gas tank pressure it will set the CIL
Re: InStant fill gas cap [Re: 87Montero] #1077217 03/17/15 03:43 PM
Malykaii Offline
How I cross refferance things... Go on rockauto and compare gas cap numbers for your car and other more popular models. When you find a match, use that new application for the stant one.
Like see if a land rover disco cap crosses, I used one on my gen1 for a bit as that's all I could grab quick at the upull after looking mine on the way there,
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: InStant fill gas cap [Re: haztoys] #1077218 06/25/15 03:03 PM
I have used these on several cars that had evap sensors and they worked fine with that. Also all new fords have these instead of gas caps.
As for the cross referencing - I use rockauto a lot to do that, and looking at all the crossreferencing I can find, it appears that there is one listed for a later model montero sport, and I assume that uses the same cap.. so maybe I will just bite the bullet and order one.
WIll let you guys know how it turns out. I put gas in the montero every other month or so and my gas cap is getting hard and hard to take off (stripped). Every time I get it off and refill I tell myself I am going to order a gas cap before the next time I need gas. <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6130 MB (Peak: 0.6833 MB) Data Comp: Off Server Time: 2026-10-21 22:04:31 UTC
