Hi all,
Long time no post. I hope you are all well!
The Mikuni carb had been molested over the years and the second barrel actuator stopped working. So I fitted a weber 32/36 and the thing went like a rocket! However, while tuning it a misfire developed and I am struggling to fix it.
When the misfire started I went to check the plugs/wires and cylinder #2 wire feel apart (only a few months old). With the wire off the engine ran the same. I replaced the plugs, wires, cap, rotor with no difference. I then played with the timing and replaced the fuel filter...nope. I am getting spark to all cylinders, verified with my timing light. May be I need to check cylinder compression?
Stuff I am not sure about;
1. when I tired to set the idle mixture, turning the screw counterclockwise does result in an idle drop. Turning is fully clockwise does not. I think I had it running rich because when driving with the engine hot, fuel was igniting in the carb <img src="/forums/images/graemlins/scared.gif" alt="" /> Not sure what to do there. I have not fitted a fuel pressure regulator yet (no dieseling). I do have one. May be that will help?
2. The secondary coil resistance is 10.5 kohms. That seemed low compared to the FSM, which says 14.5-19.5. However, coils at auto parts stores say 8.9kohms. What coils do folk use?
3. to set the timing correctly I have to retard the dizzy fully. That can't be right? timing chain issue?
Thanks all <img src="/forums/images/graemlins/kewl.gif" alt="" />
