Gen1 MAS experiment #1077596 04/07/15 01:35 PM
haztoys Offline OP
Any Gen1's down the hill do a MAS swap to tell me what you think for a HP mod to a V6 3.0 ... I dont have a real 89 MAS on my 89 ... So my test is off ... Seems to really help low end ..
Thanks
Captain Gear Box
Hazardous Toys inc
Re: Gen1 Mass experiment [Re: haztoys] #1077597 04/07/15 03:07 PM
What are you swapping? there's only a couple gen 1 V6's left down here.
Re: Gen1 Mass experiment [Re: TOASTY] #1077598 04/07/15 03:44 PM
haztoys Offline OP
Mass airflow sensor ... I would like to find a 89 V6 with a OEM MAS to try ...
Re: Gen1 Mass experiment [Re: haztoys] #1077599 04/09/15 10:59 PM
I
IncorpoRatedX Offline
you'll probably have better luck with a 90-94 turbo eclipse maf.
V45W - 1999, 3.5 sohc, winter package
L042G- 1987, 2.6 carb, auto - Cylon Raider
A112 - 1973 Galant Wagon - 4G63 Turbo, 5 speed
L023G - 1983, 2.6 carb, 5 speed manual 4WD
L028 - 1983, 4D55 turbo diesel 2WD
Re: Gen1 Mass experiment [Re: haztoys] #1077600 04/10/15 04:58 AM
Jorge has a stock '89 SWB 3.0. What would he use if you tried his?
Re: Gen1 Mass experiment [Re: JohnnyBfromPeoria] #1077601 04/12/15 11:51 PM
haztoys Offline OP
I findly got around to modding a 'round MAS' ... Have had info in my head and on paper on how they really work for some time now... Just no time to RnD the mod .. Did some rework on the circuit board to up the fuel ... Get lots more air into the motor around the MAS ... But the MAS seems to keep fueling and not going looney over the bypass of the air .. One problem with GEN1 EFI as HP goes is the MAS plugs up the intake track ... I'm at a point where the TB is now the problem ... Have a 'almost' bolt on TB that ups the TB square MM by 30 plus over stock thats nexted ... Anyone have a 89 upper intake ...?
Captain Gear Box
Hazardous Toys inc
Re: Gen1 Mass experiment [Re: haztoys] #1077602 04/20/15 01:53 AM
lordtrunks Offline
The 3.5 tb bolts onto the 3.0 upper intake machining to the intake hole needs to be done to match, I've wondered the effects of using the whole sohc upper intake and tb.
I've not done the homework on this but maybe if there is a lower intake that is ment for a multi length upper intake runners we could use the 3.5 dohc upper intake with it.
I have a whole 12v 3.0 sitting in the garage I'll have to find the maf for it but if you need a intake i can pull it i would like it back when your done with it if possible. I also have a 3.5 tb and the dohc multi length upper intake
89 2 dr turbo diesel
89/88 "Backwoods sas"
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.084s Queries: 15 (0.081s) Memory: 0.6171 MB (Peak: 0.6910 MB) Data Comp: Off Server Time: 2026-10-24 03:16:54 UTC
