Oil pressure idiot light question (adding oil pressure gauge)
#1077711
04/12/15 06:43 PM
Next weekend I will installing oil, water & volt gauges (all electric). Will I need to ground/bypass the oil pressure light? I'm assuming with the wire disconnected it will stay lit since it will not sense any pressure.
Re: Oil pressure idiot light question (adding oil pressure gauge)
[Re: promodmerc]
#1077712
04/19/15 11:22 PM
I'm about to do the same with a mechanical gauge. Does anybody know of a readily available T-fitting or something that will allow the factory idiot light sensor as well as the oil pressure gauge fittings?
'97 Sporty, 4wd/MT- Mazda/Aisin manual hubs, ghetto cold air intake. Planning- Mechanical OD auto/Dana 300 swap, SAS, and a little tooob...
[Re: 97sport]
#1077713
04/19/15 11:47 PM
They sell this at AUTOZONE: Dorman AutoGrade 1/8 in. female NPT to 1/8 in. male NPT T pipe fitting 490-186.1
[Re: Everet]
#1077714
04/20/15 12:14 AM
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Exactly why I asked. Thank you sir! Going to get one now. I hadn't looked that far into it yet, and knew somebody else had done this install...
[Re: 97sport]
#1077715
04/20/15 06:37 PM
I got my gauges installed. With the factory oil idiot light disconnected the light does not come on. Just the opposite of what I was expecting.
I didn't install a T as personally I don't see the need for the idiot light when using an actual gauge.
