Oil pressure idiot light question (adding oil pressure gauge) #1077711 04/12/15 06:43 PM
promodmerc Offline OP
Next weekend I will installing oil, water & volt gauges (all electric). Will I need to ground/bypass the oil pressure light? I'm assuming with the wire disconnected it will stay lit since it will not sense any pressure.
Re: Oil pressure idiot light question (adding oil pressure gauge) [Re: promodmerc] #1077712 04/19/15 11:22 PM
9
97sport Offline
I'm about to do the same with a mechanical gauge. Does anybody know of a readily available T-fitting or something that will allow the factory idiot light sensor as well as the oil pressure gauge fittings?
'97 Sporty, 4wd/MT- Mazda/Aisin manual hubs, ghetto cold air intake. Planning- Mechanical OD auto/Dana 300 swap, SAS, and a little tooob...
Re: Oil pressure idiot light question (adding oil pressure gauge) [Re: 97sport] #1077713 04/19/15 11:47 PM
Everet Offline
They sell this at AUTOZONE:
Dorman AutoGrade 1/8 in. female NPT to 1/8 in. male NPT T pipe fitting 490-186.1
Re: Oil pressure idiot light question (adding oil pressure gauge) [Re: Everet] #1077714 04/20/15 12:14 AM
9
97sport Offline
Exactly why I asked. Thank you sir! Going to get one now. I hadn't looked that far into it yet, and knew somebody else had done this install...
Re: Oil pressure idiot light question (adding oil pressure gauge) [Re: 97sport] #1077715 04/20/15 06:37 PM
I got my gauges installed. With the factory oil idiot light disconnected the light does not come on. Just the opposite of what I was expecting.
I didn't install a T as personally I don't see the need for the idiot light when using an actual gauge.
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.008s) Memory: 0.6042 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-07-17 02:24:48 UTC
