Gen II - OME Coils with Bilsteins 4600?
#1077743
04/17/15 03:33 AM
tried looking around haven't really found the answers im looking for. im currently looking to upgrade shocks and springs but i honestly prefer Bilstein over OME any day just based on first hand experiences. only problem is can i use OME lifted 1.25" springs with the stock length blisters?
Bilsteins rear 17.89" OME rear 18.81" extended. compressed size are almost exact?
would that 1" shortness in the bilsteins be noticeable or affect anything?
95 Montero SR - center/rear locker, Modified 6G74(200rwhp),Stock suspension, white with gloss black trim!
07 FJ Cruiser - rear locker, all stock!
Re: Gen II - OME Coils with Bilsteins 4600?
[Re: 6G74_SR]
#1077744
04/18/15 12:43 AM
You will be just fine, especially if your rear sway bar is still hooked up to limit flex. Or you can read one of the recent threads on the perfect length kyb shocks for those OME springs and be ahead of the game.
Epxo rig-98 Montero "SR" with ARB front bumper and 33x9.50's
Trail rig-97 ZJ V8 with long arms and 35's, trailer queen
[Re: Jeep2Montero]
#1077745
04/18/15 08:46 PM
thanks for the info,man id actually like to consider the monomax but lately I've been reading negative feedback like "they're leaking at 5k miles or being blown out under 10k". i have personal experience with my dads work truck an 08 tundra trd with the stock blisteins and those things can take a beating. i hit rough dirt roads at 50mph with 400lbs in the bed atlas 3 times a week and they're still running great.
but then again i can buy two sets of monomax for one set of bils. any part number on that ideal kyb for the ome spring? i tried looking for the post you mentioned but was not in luck
[Re: 6G74_SR]
#1077746
04/18/15 10:01 PM
but then again i can buy two sets of monomax for one set of bils. any part number on that ideal kyb for the ome spring? i tried looking for the post you mentioned but was not in luck http://www.4x4wire.com/forums/showflat.php?Cat=0&Number=1297081&Main=1297043
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6034 MB (Peak: 0.6596 MB) Data Comp: Off Server Time: 2026-06-07 04:37:42 UTCValid HTML 5 and Valid CSS
