How to get old valve cover gaskets out? #1077765 04/17/15 08:07 PM
F
Fujisawa_Rob Offline OP
They're 'welded' to the channel in the valve cover...I was thinking of using a heat gun to soften them up. Any suggestions?
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: How to get old valve cover gaskets out? [Re: Fujisawa_Rob] #1077766 04/17/15 08:28 PM
Very carefully go around the outside of the rubber with a razor, then kind of dig a chunk out. From there use a straight seal pick to gently spread the stamped steel under the gasket (the valve cover is upside down) lifting out the gasket. It's a pain but it can be done without damaging the valve cover.
Re: How to get old valve cover gaskets out? [Re: TOASTY] #1077767 04/17/15 08:47 PM
F
So setting them on fire is not advised? <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: How to get old valve cover gaskets out? [Re: Fujisawa_Rob] #1077768 04/18/15 12:36 AM
Ernest tried that but it warped the valve covers enough to be hard to seal.
Re: How to get old valve cover gaskets out? [Re: Fujisawa_Rob] #1077769 04/18/15 12:41 AM
Czd3my Offline
A heat gun works really well, short of setting them on fire.
1998 Montero (CW Pack)
1979 Chevy LUV 4x4
2000 GMC 2500 4X4
Re: How to get old valve cover gaskets out? [Re: Czd3my] #1077770 04/20/15 06:41 PM
F
Used a heat gun and a thin flat-bladed screwdriver. Kind of a pain, but not too bad.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6126 MB (Peak: 0.6824 MB) Data Comp: Off Server Time: 2026-05-29 15:43:31 UTC
