Page 3 of 3 1 2 3
Re: 95 Monty SR strange no start issue [Re: justcallmematt] #1077794 07/29/15 06:23 PM
danz91crx Offline
Doubt it's fuel related if starting fluid doesn't make it run. If you haven't yet you can get the FSM from Mitsubishilinks.
Site is setup so you could donate via paypal to the guy that runs the site and makes the manuals, etc easy to access.
1990 LWB RS A/T
1990 LWB Base A/T
1991 LWB LS A/T Going...Going...
Re: 95 Monty SR strange no start issue [Re: justcallmematt] #1077795 07/30/15 12:52 AM
Hopefully you guys can see this image of the board(sorry if its massive). [img]https://www.amazon.com/clouddrive/s...d6OrUQmEGSYKlqha?ref_=cd_share_link_copy[/img]
For an image to work when posting on this forum the link has to end with a .jpg or .gif or some other image file type. If it doesn't (like your link in this case) then it won't work with the image tags. But that said, I was able to paste the link into a browser and see your picture. From that, i right clicked on it to select the image url (using Chrome browser) and discovered that Amazon doesn't want you to use their site to host images that are linked to on forum pages like 4x4wire. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 95 Monty SR strange no start issue [Re: off-roader] #1077796 07/31/15 12:29 AM
justcallmematt Offline OP
Ah I should have known better, what's the right move here, edit the original post to remove the reference?
Re: 95 Monty SR strange no start issue [Re: danz91crx] #1077797 07/31/15 01:03 AM
Yeah you're probably right about the fuel. I'll check the link out, thanks for the tip.
Re: 95 Monty SR strange no start issue [Re: justcallmematt] #1077798 08/02/15 04:11 PM
My timing marks after lots of turning over. Both camshafts and the crank. Will update more later, just wanted to get these up here
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6121 MB (Peak: 0.6937 MB) Data Comp: Off Server Time: 2026-06-23 13:03:56 UTC
