1992 Montero 3.0 engine lost all compression. #1077812 04/23/15 05:49 PM
tyty Offline OP
When cranking engine sound like you have remove all the spark plug but all the spark plug are in.
I did put one to the timing belt covers to see If the belt still rotates when cranking engine and the pistons still go up and down .
Re: 1992 Montero 3.0 engine lost all compression. [Re: tyty] #1077813 04/24/15 12:05 AM
Ok.is there more to this post? With the spark plugs out, was air being pushed out when you cranked it? Have availability of a compression tester. Not sure what you mean with your second sentence.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5893 MB (Peak: 0.6368 MB) Data Comp: Off Server Time: 2026-05-29 14:33:43 UTC
