gen 1 4 cyl rear lsd #1077829 04/25/15 04:58 PM
boostin Offline OP
Just wondering if any one has a rear gen 1 lsd they would like to sell?
Thanks
Mike
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD!
1989 Mighty Max 2WD 2.6 5 speed slammed
1993 Eagle Talon TSI
Re: gen 1 4 cyl rear lsd [Re: boostin] #1077830 04/26/15 11:37 PM
Malykaii Offline
The lsd kind if sucks. Remember, I put one in simply because it came along with my 4.88 diff, not because I wanted it. When finished swapping, I left one wheel up on a jack stand and tried to drive off. It had a little grip, but didn't make it off the jack.
Maybe if you can score a very very low mileage one it might be ok. My mustang's high mileage lsd didn't even have an ounce of grip before the diff died, and when I found a 55k mile used axle, that lsd was better, but still not impressive. Just enough to get out of frozen parking spots,
If you bought new clutches or restacked it in a better fashion then you'd get some real grip, but for all that work just get a locking axle? Or is that easier said than done in Canada?
Worst case when I do the 4.90 locking axle swap, I can send you the lsd piece when I separate and save the 4.88 gears. But it's not worth the effort in my opinion.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: gen 1 4 cyl rear lsd [Re: Malykaii] #1077831 04/27/15 05:02 AM
I've never had any issues with the Mitsu LSD being 'loose'. I've had the opportunity many times to do a 2-wheel burnout with the turbo Mighty Max and my gutless Raider.
Re: gen 1 4 cyl rear lsd [Re: rxinhed] #1077832 04/27/15 06:03 PM
I know my gen I v6 LSD was very tight aiding me through the 'con and only requiring a couple of straps to get through. <img src="/forums/images/graemlins/kewl.gif" alt="" />
If the clutch plates are toast though I would imaging they could be replaced or rebuilt.
Re: gen 1 4 cyl rear lsd [Re: off-roader] #1077833 04/28/15 03:03 AM
Also a fresh change of fluid with some new LSD additive helped mine a bunch. Food for thought.
Re: gen 1 4 cyl rear lsd [Re: off-roader] #1077834 05/02/15 10:26 PM
Malykaii Offline
They are available from Mitsu, but for the ridiculous amount they want to charge, it makes an air locked,disk brake axle look cheap. I've read up a lot on grabbing another used friction plate and swapping it out for a disk to tighten things up. Am considering that for the front.
Also, I guess I never had good luck with LSDs based on all of your posts. Oh we'll.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6109 MB (Peak: 0.6825 MB) Data Comp: Off Server Time: 2026-11-03 04:52:57 UTC
