Trailer light question
#1077839
04/27/15 12:11 AM
Is there any way to wire a 97 Montero for trailor lights using just a 4 wire system? I'm preplexed. Any vehicle with separate blinkers will have this problem. I need another wire and I'll be damned if I can figure out how to get brakes, running lights and blinkers active on only 2 wires. I tried jumpers but that blew my tail light bulbs.
97' Montero SR 99' F250 SCLB 7.3
Re: Trailer light question
[Re: DVoeks]
#1077840
04/27/15 02:05 AM
not sure its the same, but my '92 & '93 are wired this way.
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
[Re: DVoeks]
#1077841
04/27/15 02:52 AM
You need this: Manufactured by Hopkins, it's called a Hoppy 46255 Power Taillight Converter
98 Gen 2.5 05 Pontiac GTO 91 Corvette ZR-1 2011 Kia Sorento (wifey mobile) Clarkdale, AZ
[Re: monte3]
#1077842
04/27/15 05:04 AM
You need this: Manufactured by Hopkins, it's called a Hoppy 46255 Power Taillight Converter Thanks man. I ordered one from Amazon earlier today. I just could not figure out a way to make it work any other way.
[Re: DVoeks]
#1077843
04/28/15 09:43 PM
FYI, I just installed a 7-way RV connector with a brake controller. It requires some custom wiring and the use of the controller mentioned above, but is doable. It took a few days, but I can now power trailer brakes and recharge an rv battery if needed.
Frank in AZ
[Re: ktsdad]
#1077844
04/28/15 09:58 PM
FYI, I just installed a 7-way RV connector with a brake controller. It requires some custom wiring and the use of the controller mentioned above, but is doable. It took a few days, but I can now power trailer brakes and recharge an rv battery if needed. Nice. Can you post up the wiring you used? A diagram would be awesome if possible! <img src="/forums/images/graemlins/kewl.gif" alt="" />
