Page 3 of 4 1 2 3 4
Re: head gasket repair [Re: JohnnyBfromPeoria] #1077955 05/13/15 01:29 AM
F
fzj80joe Offline OP
so I'm just going to use some nylon bushings that are really close to the correct size for a temporary fix instead of leaving the assembly out.
then when I have more money I will replace it with the newer unit.
Should work fine. Use Loc-Tite on the screws, of course.
As I'm sure you remember, that o-ring I gave you goes on the back of the back half of the water pump and seals the metal water tube.
If you need any O-rings to try to seal the front of the butterfly shaft where it exits the front of the lower plenum, I have a metric kit or you can get a whole set from Harbor Freight.
Good work with the Time Sert. I'm really impressed with their product. It has saved a few of us on here so far.
Yes thanks for the reminder on that o ring. I will just buy a metric one for the butterfly shaft. the bushings i found were perfect for fitting in the plenum and the hole for the shaft was bout .020" big but its not that bad for a temporary fix.
Re: head gasket repair [Re: fzj80joe] #1077956 05/13/15 02:33 AM
All of the current valve guide seals are the former exhaust seals, there are not supposed to be intake-specific seals any more.
Do you have cam seals for the front and rear of the heads? Maybe that's why you have 8 instead of 4.
Sorry I missed your call. I was asleep.
Re: head gasket repair [Re: JohnnyBfromPeoria] #1077957 05/13/15 02:53 AM
I think you're missing a digit on those valve stem seals. I show p/n MD307343.
Re: head gasket repair [Re: JohnnyBfromPeoria] #1077958 05/13/15 04:47 AM
F
fzj80joe Offline OP
you're right I missed the last 3 in there but you're saying that i should use the MD306079's only ?
I want to take the correct ones over to the machine shop in the morning so they can assemble the heads and i can get this party rolling.
Re: head gasket repair [Re: fzj80joe] #1077959 05/13/15 06:46 AM
All the MD306079's go back. Do NOT use them. See my post in the other section. I have you covered.
Re: head gasket repair [Re: JohnnyBfromPeoria] #1077960 05/14/15 11:29 PM
F
fzj80joe Offline OP
I called the shop this afternoon and they said they were bolting the cams back in the heads so I'm hoping to get them back before COB
and I'm on hold with the salesman getting he tracking number for your replacement valve guide seals
Thanks again for all the help!
And the neighbors wifi is back on <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: head gasket repair [Re: fzj80joe] #1077961 05/15/15 12:40 AM
Let's hope they labeled the cams, for some reason shops like to think that they are all the same. Then they're wrong and the truck runs like crap.
Re: head gasket repair [Re: TOASTY] #1077962 05/16/15 05:10 PM
F
fzj80joe Offline OP
Do you know how to identify what cams go where? when i put the timing belt on the cams on the drivers side engine lined right up with the marks on the valve cover but on the passenger side when I lined them up they kept wanting to spin out of position?
is that normal for these engines when you're putting the timing belt on?
i can rotate the engine by the crank and the cams and crank are all on the correcting marks
Re: head gasket repair [Re: fzj80joe] #1077963 05/16/15 06:31 PM
ryany Offline
That's normal behavior for that engine - one of the reasons it's such a pain to get the timing belt on and everything timed correctly. Based on that I'd guess you've got the cams in the correct locations.
95 Montero SR
Re: head gasket repair [Re: ryany] #1077964 05/16/15 09:02 PM
F
fzj80joe Offline OP
good to hear thats normal. I haven't done a timing belt in about 10 years. It took a few attempts, when I would set the tension idler it would move the cam sprockets.
now I just need to figure out how the wiring went get the fuel rail, intake, exhaust and anything in front of the motor I removed.
Page 3 of 4 1 2 3 4
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6426 MB (Peak: 0.7682 MB) Data Comp: Off Server Time: 2026-06-07 10:16:35 UTC
