3rd gen ABS ring removal....HELP! #1078052 05/12/15 01:49 AM
CORunner93 Offline OP
I'm looking for some help with a 3rd gen axle rebuild, Does anyone know how to correctly remove the 3'rd gen rear axle ABS ring? We pulled the half shafts out and and found this ABS ring (looks like a sprocket) just behind the bearing. It appears to be pressed on....but, I'm not sure. We went to a machine shop and the guy there said it needs to be cut off. I'm not buying that....and I hate the idea of using an angle grinder on a machined surface. Any idea?
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: 3rd gen ABS ring removal....HELP! [Re: CORunner93] #1078053 05/25/15 04:17 AM
Jeff the marmot Offline
I was told by a Toyota service shop (not a dealer) that they prefer to replace those rear ABS rings with a new part because they typically get damaged after trying to remove them with a press. Otherwise, I also heard them say they like to cut them off instead of trying to save them and press them off. I had my rear ABS rings removed during an axle rebuild process and they definitely looked beaten up afterward. I chose to buy new ABS rings after seeing that.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5898 MB (Peak: 0.6378 MB) Data Comp: Off Server Time: 2026-05-29 15:34:06 UTC
