post head gasket problems #1078112 05/18/15 09:33 PM
F
fzj80joe Offline OP
well I finally put everything back together after doing my head gasket.
The engine fired right up and is very responsive.
but it still smokes.
and the valves are really loud now. they werent before the project
When it warmed up i was trying to burp the cooling system and there wasn't any flow in the radiator. The upper hose was hot but the bottom one was cold. Did i install the thermosat wrong? its brand new OEM
when i shut off the engine some coolant dribbled out from behind the timing cover i think . the water pump was also replaced.
Re: post head gasket problems [Re: fzj80joe] #1078113 05/18/15 09:34 PM
F
fzj80joe Offline OP
its on a 95 3.5 DOHC.
Re: post head gasket problems [Re: fzj80joe] #1078114 05/19/15 07:37 AM
From your post on the AZCrew section, it sounds like you got this all resolved.
Re: post head gasket problems [Re: JohnnyBfromPeoria] #1078115 05/19/15 07:15 PM
Jay Ayala Offline
I went and read the post on the AZ Crew forum. It seems like everything is resolved. Yes, I agree with JohnnyB about the remaining smoke being residual burn off. A good trip around Phoenix freeways will probably clear all of that up.
I'll take this opportunity to post some helpful reminders about the valve seals and the hydraulic lash adjusters.
1989 V6 - Servicing your Hydraulic Lash Adjusters
1989 V6 - Valve Seal Replacement - Cylinder Head removed
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6022 MB (Peak: 0.6582 MB) Data Comp: Off Server Time: 2026-10-22 02:20:59 UTC
