Page 3 of 3 1 2 3
Re: overheating problem [Re: promodmerc] #1079190 10/03/15 01:59 AM
Dave Scott Offline OP
Ok, got the new radiator in. More of a pain in the @$$ than I remember. Changed the oil, added some transmission fluid as some leaks when you disconnect to swap the radiator, then I overcharged my a/c. Got no boiling out on the way home, about 45 miles, but I did see some coolant on the top of the radiator near the cap. I had tested the water pump and it sprayed coolant everywhere, so I hope that's all it was. The a/c compressor is now clicking on and off constantly. Can I just evacuate some R134 until it's back to normal?
Re: overheating problem [Re: Dave Scott] #1079207 10/05/15 04:52 PM
promodmerc Offline
Got mine fixed Saturday. I had the old radiator out in just over an hour. (I have a 5 speed so I didn't have to deal with the trans line connections) Took more time going back in as I was being very careful not to damage the new one.
I also replaced my lower radiator hose as I had forgot I had cut it a little jagged when I replaced it last year when I replaced the timing belt, water pump & components.
Re: overheating problem [Re: Dave Scott] #1079229 10/07/15 05:10 PM
promodmerc Offline
Well now it seems the fan clutch is bad too. Got one ordered. In the future I might add an electric fan, just don't feel like messing with that right now.
I had thought hard about a flex fan but a friend talked me out of that idea.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6024 MB (Peak: 0.6722 MB) Data Comp: Off Server Time: 2026-05-29 15:34:19 UTC
