CV Joint removal #1078173 05/23/15 12:53 AM
F
fzj80joe Offline OP
Okay,
I got the CV axles out and I removed the torn inner boots
I removed the clip on the outboard side of the inner joint.
But I still can't remove the joint
does anyone know the next step?
I tried getting one of the balls out to start removing the cage but it doesn't seem to flex that far.
Thanks,
this is on my 95 SR
Re: CV Joint removal [Re: fzj80joe] #1078174 05/23/15 03:47 PM
There's a circlip holding the star in place, likely covered in grease.
Re: CV Joint removal [Re: TOASTY] #1078175 05/26/15 01:28 AM
F
fzj80joe Offline OP
Yup, Once I cleaned out more grease I found the second clip. its a wire like clip that goes around the inside perimeter of the cup.
I got them apart. cleaned greased and re booted and everything is back together.
Re: CV Joint removal [Re: fzj80joe] #1102647 12/17/16 01:50 AM
O
Omardottcom Offline
How do you remove the circlip?
Owner of 1995 Mitsubishi Montero
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6007 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-07 06:10:48 UTC
