engine idle low then dies
#1078194
05/27/15 01:40 AM
okay next question for the person who is new to monteros.
I was going down the highway and it started to stutter then it died. I rolled off the ramp and then it would start idle really low like 250-350rpm and if i gave it throtlle it would very hesitantly rev to maybe 1200 rpm max. and then die.
I turn the key to accessory and couldn't hear the fuel pump and it kinda felt like a fuel pump so i changed the fuel pump but that wasn't it.
before this sometimes when it was cold out it would idle ruff but it would smooth out after a few seconds. so now I'm beginning to think it must be some kind of sensor.
I grounded the number 1 terminal on the edu connector and turned the key on and counted the check engine light blinks but it just never stopped blinking.
there isn't a fuel pressure port so I can't check if its fuel and its a lot of work to pull the intake and check all the plugs for spark
but the engine sounds really smooth for the most part just idles really low then if i rev it up a little it sputters and dies.
whats the next step for trouble shooting these engines?
Re: engine idle low then dies
[Re: fzj80joe]
#1078195
05/27/15 02:29 AM
Rig/Engine/Year? That'll get you more specific diagnosis...
[Re: PHIL_]
#1078196
05/27/15 08:20 PM
sorry it was on my 95 SR 3.5
I pulled the coils and checked them one of them tested bad from the spark plug boot end to the spark plug wire. so i replaced that it it still ran the same way.
it was running and i disconnected the MAF sensor and then gave it some throttle and instead of dying it reved up so i did that a few times and it never died but it was running in the limp mode.
so i changed the MAF and it runs good now.
I don't know why it didn't kick out a check engine light until i actually disconnected it but that seems to be what the problem was.
thanks!
[Re: fzj80joe]
#1078197
05/27/15 08:42 PM
Can you drive it in limp mode? I have a MUT-II computer, should be able to diag your truck. I'm still learning how to use it so no guarantees. I've about got it figured out on the newer Montero's but i haven't quite got it to tap into the Pre '98 trucks yet. I think they take the other rom pack i have.
[Re: fzj80joe]
#1078198
05/28/15 01:49 AM
Mines doing something similar to yours. Does anyone know the test procedure for the MAF sensor.
1990 LWB 3.0 Auto Tan interior Mostly Stock 194k
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6075 MB (Peak: 0.6731 MB) Data Comp: Off Server Time: 2026-06-07 06:11:22 UTCValid HTML 5 and Valid CSS
