Need a GEN I fan assembly #1078270 06/06/15 11:34 PM
L
Liltrbo Offline OP
My Monty has the 3.0 6cyl with an aftermarket electric fan. I keep killing fans. They just don't last underwater. I'm assuming the rig came from the factory with a mechanical fan. Am I wrong? I'm hoping to find what I can to convert it back to mechanical. Thanks! Steve
Re: Need a GEN I fan assembly [Re: Liltrbo] #1078271 06/08/15 04:10 AM
RECON45 Offline
they did come with a mechanical fan. It bolts right ontop of the pulley. so you will need longer bolts on the pulley, the fan, and the 2 piece fan shroud to make it back complete. Should not be hard to find
Re: Need a GEN I fan assembly [Re: RECON45] #1078272 06/11/15 11:08 PM
heathdogg Offline
If I hit the u pick it this weekend (if it stops raining) I'll look to see if it is all there. FYI, I put studs instead of bolts. Seemed to be easier for me.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Need a GEN I fan assembly [Re: Liltrbo] #1078273 06/20/15 07:00 PM
MI_Mitsu Offline
Let me know if you still need a fan - I have 2. One with the clutch still installed, 1 with it removed, but I still have the fan clutch available for that one too.
Re: Need a GEN I fan assembly [Re: MI_Mitsu] #1078274 08/04/15 11:52 PM
L
Liltrbo Offline OP
Yes, I still need it! I've been sidetracked on other projects but I'm back to the Monty. I'll shoot you an email. Thanks for responding!
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6076 MB (Peak: 0.6722 MB) Data Comp: Off Server Time: 2026-05-27 21:18:15 UTC
