6g74 dohc gen 2 - sudden power loss at 4krpm now no power #1078337 06/23/15 03:45 AM
6
6G74_SR Offline OP
whats up guys im having a bit of an issue.
last night at 65F degrees about 2000 meters elevation i was driving and went to pass a car and floored it WOT and at around high 4k rpm the car suddenly lost all power and felt like an experience of when you miss a gear in a manual car.
at first i thought it was a transmission issue but noticed it was still shifting fine except it was sluggish as hell. no smoke no noise, was able to drive home but couldn't even keep up with traffic. at idle it sounds like a tractor barely stays on idling roughly 500rpm.
what can it be? spark plug, wires, coil pack , sensors?
95 Montero SR - center/rear locker, Modified 6G74(200rwhp),Stock suspension, white with gloss black trim!
07 FJ Cruiser - rear locker, all stock!
Re: 6g74 dohc gen 2 - sudden power loss at 4krpm now no power [Re: 6G74_SR] #1078338 06/24/15 04:43 PM
ryany Offline
Because of it hapenning suddenly like you describe, I'd suspect something like the timing belt slipping, or one of the variable intake throttle plates came loose and was swallowed by the engine. What is the timing belt and tensioner history on the vehicle and have you ever inspected the lower intake butterflys?
95 Montero SR
Re: 6g74 dohc gen 2 - sudden power loss at 4krpm now no power [Re: ryany] #1078339 06/25/15 04:52 AM
6
6G74_SR Offline OP
Problem Solved!! luckily it wasn't all that, i had thought about it at first but the motor was built only almost 8k ago (butterfly valve and new timing built along with the rest of the build)
i bought some quality grade contact cleaner and went ahead and polished the battery terminals, the ground contact cable
then went ahead and removed all fuses sprayed some cleaner, removed every electrical sensors above the intake manifold cleaned them, removed all three coil packs cleaned that aswell as the spark plug wire terminals
lastly removed the intake, deeply cleaned the mass air flow, throttle body, IAC and attached sensors.
put everything together and this baby started back up 100% normal. actually idles more steady a bit higher than before 900rpm with no shutters. drove a couple of miles and drove great tomorrow ill hit the highway and find out forsure.
i believe it was due to a loose connection to a coil or dirty MAF, thanks for the advice anyways
Re: 6g74 dohc gen 2 - sudden power loss at 4krpm now no power [Re: 6G74_SR] #1078340 06/25/15 07:28 PM
6
6G74_SR Offline OP
bad news woke up to the same issue now idling bad again, i begin to suspect bad IAC valve i will check up on it now
Re: 6g74 dohc gen 2 - sudden power loss at 4krpm now no power [Re: 6G74_SR] #1078341 06/25/15 09:05 PM
ryany Offline
An IAC valve won't effect anything other than idling conditions.
95 Montero SR
Re: 6g74 dohc gen 2 - sudden power loss at 4krpm now no power [Re: ryany] #1078342 07/08/15 11:30 PM
6
6G74_SR Offline OP
i was under the impression that a faulty motor on the IACV would cause it to malfunction and not retract causing the engine to not run properly in any RPM.
Re: 6g74 dohc gen 2 - sudden power loss at 4krpm now no power [Re: 6G74_SR] #1078343 07/09/15 02:37 AM
ryany Offline
I don't think the IAC valve can let any unmetered air into the engine, so it shouldn't have any effect on normal running conditions. Even if it is unmetered air, the amount the IAC valve is capable of allowing in shouldn't have anywhere near the effect on the engine that you're experiencing.
95 Montero SR
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6204 MB (Peak: 0.7108 MB) Data Comp: Off Server Time: 2026-06-07 08:29:28 UTC
