A/T Temp light coming on - normal driving #1078350 06/23/15 10:36 PM
mrray Offline OP
Hey all.
Awhile back I posted thinking my sensor was off. But now it seems the light is coming on after about 40 min of normal driving. No demonic hills or towing. Just running errands.
Fluid level is fine. Pump issue? What could cause this?
Poor girl just can't get healthy...
1991 Montero LS (LWB) 3.0L V6 Stock 205K Miles
Re: A/T Temp light coming on - normal driving [Re: mrray] #1078351 06/24/15 03:46 AM
Could be a short across the switch sensor or cap...the parts are old and used now.
Re: A/T Temp light coming on - normal driving [Re: rxinhed] #1078352 06/24/15 05:36 AM
Has it ever gotten fresh fluid? also it will generate more heat if your screen is getting clogged, they are cheap to replace but they are also reusable so you could just clean it. It wouldn't hurt it to have it flushed and filled with some Diamond SP and a new or cleaned screen. It's a cheap gamble compared to a transmission, worst case you have new fresh fluid and a filter which isn't a bad thing.
Re: A/T Temp light coming on - normal driving [Re: rxinhed] #1078353 06/24/15 05:01 PM
mrray Offline OP
I should go ahead and buy the replacement to rule this out.
Re: A/T Temp light coming on - normal driving [Re: TOASTY] #1078354 06/24/15 05:07 PM
mrray Offline OP
It had a flush / new fluid about 5 years ago. It hasn'T seen much driving time since then as its a utility / fun vehicle and not a DD. Also, it got sick and was parked for about a year.
I notice that when the light comes on, I can sit in idle for a few mins and the light goes off. That makes me think it is not a faulty sensor, unfortunately.
I'll check the fluid again and make sure it's still pink. If it is, then I can change / clean the screen without dumping the fluid? I thought you had to drop the pan to get to anything.
Re: A/T Temp light coming on - normal driving [Re: mrray] #1078355 06/24/15 05:09 PM
mrray Offline OP
PS: I'm jealous you have a delica!
Re: A/T Temp light coming on - normal driving [Re: mrray] #1078356 06/25/15 12:37 AM
It's for sale!
Good luck with the fix dude!
Re: A/T Temp light coming on - normal driving [Re: TOASTY] #1078357 06/25/15 05:00 AM
6
6G74_SR Offline
Does your A/T light stay on or blink intermittently. if it stays on it is due to overheating of the fluid or overall transmission temp. if it blinks it is due to an electrical issue like a faulty speed sensor. this applies to my monty it may not apply to yours.
if its overheating best bet is full flush including secondary cooler and if it doesn't have one consider getting one.
95 Montero SR - center/rear locker, Modified 6G74(200rwhp),Stock suspension, white with gloss black trim!
07 FJ Cruiser - rear locker, all stock!
Re: A/T Temp light coming on - normal driving [Re: TOASTY] #1078358 06/26/15 12:06 AM
mrray Offline OP
It's for sale!
It would have to be really comfy inside, as my wife would disown me!
Let me think about it...
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: A/T Temp light coming on - normal driving [Re: 6G74_SR] #1078359 06/26/15 12:09 AM
mrray Offline OP
I'll probably do another flush to be safe. It does flicker a bit, but then stays on, like the temp is "tickling" (can I use that word on a truck forum?) the threshold before it comes on solid. Then it goes off after sitting in idle for a few mins.
I hate opening transmissions. I feel like I'm opening a demon portal...
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6419 MB (Peak: 0.7667 MB) Data Comp: Off Server Time: 2026-05-29 18:59:57 UTC
