1989 Raider Air Conditioner #1078367 06/24/15 11:14 PM
mfarmer10 Offline OP
Hey guys, I've been thinking about installing my ac unit. The guy I bought it from never put it back in after rebuilding the engine and he gave me all the parts for it. Has anyone had experience with this? Is it a difficult install. Also, if you have some pictures of your unit so I can see where everything bolts up that would be awesome.
Thanks,
Mackinley
Re: 1989 Raider Air Conditioner [Re: mfarmer10] #1078368 06/25/15 12:27 AM
2.6 or 3.0? You should put that in your signature.
Re: 1989 Raider Air Conditioner [Re: Mudraider] #1078369 06/25/15 01:01 AM
3.0, sorry about that
Re: 1989 Raider Air Conditioner [Re: mfarmer10] #1078370 06/25/15 04:09 AM
Are you attached to Ft. Bragg, home of America's Guard of Honor the 82nd Airborne Division?
Re: 1989 Raider Air Conditioner [Re: Mudraider] #1078371 06/29/15 07:03 PM
bearingman Offline
I'm over in St. Pauls, just south of Fayetteville. You're more than welcome to come down and "study" mine all you want. I have 89 Montero 3.0 SWB
Re: 1989 Raider Air Conditioner [Re: bearingman] #1078372 06/29/15 07:12 PM
That's what I have. Mine leaks behind the firewall. Close to becoming a J-top. After I get moved into the new house, going to give it one more try to find a leak. Have you looked in mitsubishilinks.com and check out the troubleshooting charts there?
Re: 1989 Raider Air Conditioner [Re: bearingman] #1078373 06/29/15 09:52 PM
bearingman Offline
Sorry, I meant to reply to FARMER. I have no leaks (except for the big hole in the oil pan that put her down) <img src="/forums/images/graemlins/frown.gif" alt="" />. I'm about 40 miles from him. He could just come over and buy mine and take it home and study her over real good. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 1989 Raider Air Conditioner [Re: Mudraider] #1078374 06/30/15 03:43 PM
mrray Offline
Have you checked the mating surface between the chassis and the outside our inlets? I had a frustrating leak a while back and only found this after tearing the whole dash apart and reinstalling the windshield.
1991 Montero LS (LWB) 3.0L V6 Stock 205K Miles
Re: 1989 Raider Air Conditioner [Re: mrray] #1078375 07/04/15 02:04 AM
djacidjac Offline
I had mine apart to convert it to an air compressor after I replaced the head. It was leaky and low on r12 anyway. I noticed most of the o-rings were shot. I think it'd be a good idea to replace all the o-rings. There's one at every joint in the system as far as I can tell. You *should* replace the filter/dryer with a new one since it's been exposed to air/moisture. You can still get r12, it just costs a lot. Maybe you can get a deal if you know somebody in refrigeration. I'm told it works a lot better than the replacement, r134a. Of course you'll have to pressure test, evacuate it, and weigh in the refrigerant. I guess you're going to have a shop do that. Just my first thoughts. Good luck. I'd like to see how it works out. One day I'd like to get mine working again.
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6275 MB (Peak: 0.7306 MB) Data Comp: Off Server Time: 2026-06-07 07:28:01 UTC
