fuel cell evap? #1078449 07/04/15 01:54 AM
djacidjac Offline OP
I'm replacing my stock tank with a plastic fuel cell. keeping it in the normal spot underneath. Should I bother reproducing the stock vapor line taps (x3) and separators (x4) or should I just use a single vapor tap and a separator or two? Open to options and suggestions. trying to keep costs down but still want vapor recovery.
other misc info: using perf strap and angle iron to hang it for fitment and testing, then bending up an aluminum tray / skidplate once it's finalized (keeping the perf strap on top).
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: fuel cell evap? [Re: djacidjac] #1078450 07/04/15 04:14 PM
I guess my real question for everybody here is:
What is the easiest way to connect my new tank to the evap' system? I'm thinking of teeing into the fill breather, adding 2 separators and that's it.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5872 MB (Peak: 0.6352 MB) Data Comp: Off Server Time: 2026-05-29 17:53:20 UTC
