Gen 1 SWB: Got an extra set of rear springs in a parts yard. What to add in?? #1078509 07/12/15 11:54 PM
TresMon Offline OP
So I made a major score at parts at a parts yard. I went ahead and took the rear spring packs out of the junk yard monty too. I'd like to add in a leaf or two as my springs are tired.
Should I add in a long spring, short or one of each? Is their a source for center bolts for the spring packs? Something universal?
Thanks!
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: Gen 1 SWB: Got an extra set of rear springs in a parts yard. What to add in?? [Re: TresMon] #1078510 07/13/15 04:27 AM
Save yourself some time and find some Gen II Mighty Max rear springs, say 87 to 90 model. They have the military wrap and a little more arch, plus one more leaf already.
Re: Gen 1 SWB: Got an extra set of rear springs in a parts yard. What to add in?? [Re: rxinhed] #1078511 07/14/15 02:11 AM
TresMon Offline OP
Is the mighty max a truck?
These springs were practically free, and I have way more time than money.
Any body know if it's better to add in long leaves or short?
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: Gen 1 SWB: Got an extra set of rear springs in a parts yard. What to add in?? [Re: TresMon] #1078512 07/14/15 02:59 AM
zarktheshark Offline
I added all but the main leaf and the over loads and I do NOT recommend doing that. since I was having my parts rig towed, I left the main leafs on the donor vehicle (mistake 1). If you are going to do this, take the main leaf and cut the eyes off. If you don't and do what I did, the other added leaves will create a pressure point on the main leaf and it will slowly eat away at the main leaf. That's why I have OME's now smile
If I were to do it again, I would remove the over loads, add the cut main leaf and see how I like it. I did that with my Jeep back in the day and it worked well. not sure how much lift you will get from just the main leafs. On my "wrong" setup, I ended up with 1.5-2in lift.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Gen 1 SWB: Got an extra set of rear springs in a parts yard. What to add in?? [Re: TresMon] #1078513 07/15/15 09:21 PM
Mighty Max / D-50 = Mitsubishi 1/2-ton pickup
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6106 MB (Peak: 0.6761 MB) Data Comp: Off Server Time: 2026-10-21 16:21:08 UTC
