Re-installing front crossmember #1078514 07/13/15 02:00 AM
A
AcadianaRaider Offline OP
Finally finished with the balance chain, guides, timing chain, and oil pump replacement on my 87 2.6l Raider. The last part was to re-install the oil pan and then replace everything I had removed or loosened to manuever the pan out and in. For those that tackle the oil pan in the future, I had a lot of luck with removing the crossmember and loosening the differential mounts until the nut was just barely on the bolt. This pivoted the diff enough to give me plenty of room to get the pan back in.
The question I have is what do I have to do to get the crossmember mounts to line back up? If I mount one side, the other will not line up. Do I need to jack the front end up and get some of the stress off of the lower arms? Also, is it OK to drive (on road, around town) without the crossmember mounted? I've had this thing in my garage for 6 months and I'm ready to drive it again. It's running very well after all of the replacements I mentioned above. What started all of this was a noisy balance chain that I ignored and it eventually broke. I was very lucky to not have any additional damage.
Thanks, Jeff
1987 Raider, 2.6L, 5spd, Weber carb
Re: Re-installing front crossmember [Re: AcadianaRaider] #1078515 07/13/15 04:15 AM
If'n it's like any other vehicle I've messed with, it will be an act of Congress to get it all lined back up. A come along, and a good strong crow's foot will help
Re: Re-installing front crossmember [Re: Mudraider] #1078516 07/19/15 04:53 PM
lordtrunks Offline
flat head screw driver and crowbar is what i have used and worked everytime. also don't drive it without the crossmember in.
89 2 dr turbo diesel
89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 1.100s Queries: 15 (1.070s) Memory: 0.5969 MB (Peak: 0.6517 MB) Data Comp: Off Server Time: 2026-10-24 08:18:05 UTC
