1999 Montero Sport Limited A/T model? #1078524 07/14/15 10:57 PM
ES_97Sport Offline OP
Apologize if this is a stupid question. I'm not an A/T guy. <img src="/forums/images/graemlins/smile.gif" alt="" />
Does anyone know what A/T came in the Montero Sport Limited 3.5L? Can't remember if that was AWD only or if there was an option.
Might be able to pick up a '99 cheap and that may turn into my next build. Don't really want to go through the hassle of another M/T and dual t-cases.
Re: 1999 Montero Sport Limited A/T model? [Re: ES_97Sport] #1078525 07/18/15 02:58 AM
Ian Sharpe Offline
dont know about the sport, I think it is similar to our challenger.
But the auto in the Gen 2.5 monteros is the Asian Warner AW4
as used in Jeep Cherokees.
Auto with the dual cases is absolutely unstoppable!
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
Re: 1999 Montero Sport Limited A/T model? [Re: Ian Sharpe] #1078526 07/19/15 09:40 AM
lordtrunks Offline
asa is showing v4a51 i don't recall that year having awd
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: 1999 Montero Sport Limited A/T model? [Re: lordtrunks] #1078527 07/20/15 09:43 PM
... But the auto in the Gen 2.5 monteros is the Asian Warner AW4
Thanks, Ian. Yep, knew about that. I'm just trying to make sure I have my ducks in a row. I'm working on picking up a '99 Limited 3.5L now. Haven't seen it yet and the owners are out of town and know NOTHING about this thing.
I want to MAKE SURE this will easily take the NP dual t-case conversion BEFORE I buy. smile Wouldn't think of building another Sport without the t-cases now. Spoiled. smile smile
Thanks! Don't remember. Been so long since we had the '99 .... I'm thinking now that the '99 Limited didn't come with AWD, that that started in '00. Anyway, no AWD is what I want, so .... Just trying to make sure I get the 3.5L. Dynatrac axles are pigs - don't want to try the passes with a 3.0L. smile
So, again, pardon any stupid questions, but this IS the transmission everyone has been putting the dual t-cases on, right? Replace the tail shaft, output, etc, and bolt up the NP231 23-spline?
Re: 1999 Montero Sport Limited A/T model? [Re: ES_97Sport] #1078528 07/21/15 11:38 PM
lordtrunks Offline
BEWARE THIS IS NOT THE SAME AUTOMATIC! <img src="/forums/images/graemlins/frown.gif" alt="" /> If i remember correct dannytuned swapped it out for a montero tranny so he could double up send him a pm
Re: 1999 Montero Sport Limited A/T model? [Re: lordtrunks] #1078529 07/22/15 01:01 AM
AH! Yep, and this was why I posted. smile Will do! Thanks!
Re: 1999 Montero Sport Limited A/T model? [Re: ES_97Sport] #1078530 07/22/15 03:33 AM
Ian Sharpe Offline
ES,
The tranny you want if its from a Mitsu is the V4AW3, the NP231 & NP 242 bolt up to it but you have to swap in a tailhousing from a Jeep Cherokee that has the AW4 tranny (Jeeps version of the V4AW3).
I have done this recently using a Behemoth Strong Box mated to an NP 242.
You might be better sourcing a tranny out of a Gen 2.5 Montero or a Jeep Cherokee.
heres my writeup.
http://www.4x4wire.com/forums/showf...&an=0&page=1#Post1292901
Re: 1999 Montero Sport Limited A/T model? [Re: Ian Sharpe] #1078531 07/23/15 09:39 PM
Thanks Ian. DANG. Dang, dang, dang. <img src="/forums/images/graemlins/frown.gif" alt="" /> PM'd Danny and when through his thread. The transmission appears to not be the issue, of course, its the computer(s). Again. <img src="/forums/images/graemlins/frown.gif" alt="" /> Looks like he used my suggestion on the shift solenoids. That worked. The T/C was an aftermarket controller? If I have to do all the sensor/solenoid hacks I might as well drop a 5-speed M/T in. Sigh.
This could be just as difficult as getting the A/T PCM working in my M/T. Mmmmm.
Re: 1999 Montero Sport Limited A/T model? [Re: ES_97Sport] #1078532 08/03/15 11:33 PM
Consolidating to a build thread so everything is in one thread.
1999 Montero Sport Limited 3.5L crawler build
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6333 MB (Peak: 0.7388 MB) Data Comp: Off Server Time: 2026-07-13 18:31:23 UTC
