Power Steering Pump and Reservoir #1078652 08/01/15 12:25 AM
L
Leopard14 Offline OP
Hello everyone,
sorry if this may be a repeat or a common question (new to the forum), but I don't think I ran across the information I needed in the tech manuals. My situation is:
My power steering pump and attached reservoir have a leak, there seems to be some kind of bracket or brace missing (it is put together with tie ties) from the top. Is there a better pump to put in it's place (a modification) from a similar vehicle, if not where exactly besides the dealer would the bracket or brace be found. Sorry, I was not able to find a good visual to show me what is supposed to hold these two things together.
But, I know there are probably a few ingenious people who have run across this problem and figured out a fix or a better solution than the original set up.
Thank you for your time and help....
Leopard
Re: Power Steering Pump and Reservoir [Re: Leopard14] #1078653 08/01/15 02:39 AM
MarkG Offline
Have you looked at www.car-part.com ?
You didn't post what model, year or engine you have. You will need that information to do a search on car-part.com.
Re: Power Steering Pump and Reservoir [Re: MarkG] #1078654 08/01/15 05:57 AM
L
Sorry, 1987 Dodge Raider, 2.6 engine.
All I can find is photos of the power steering pump without the reservoir. I need to be able to see the pump and reservoir from the top, so that I can see the bracket, pictures of what holds the reservoir to the pump itself would be nice. There is a leak, but I believe it is a bad o ring where the hose connects to the pump.
Re: Power Steering Pump and Reservoir [Re: Leopard14] #1078655 08/02/15 11:59 PM
MarkG Offline
Have you checked http://www.mitsubishilinks.com/ ?
Look for the section "Parts Catalogs" then "Raider_partscatalog_1989". This is a scanned copy of the 1989 parts catalog. See chapter 19-Power Steering. It shows all the brackets and braces for both the 4 cyl and 6 cyl engines.
I scanned the paper catalog about 15 years ago. It's available for anyone. You may want to donate to http://www.mitsubishilinks.com/ for hosting it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Power Steering Pump and Reservoir [Re: MarkG] #1078656 08/03/15 11:18 PM
heathdogg Offline
So my 87 Raider had a reservoir bolted to the back of the pump that was connected via a little hose that bolts on the side of the pump. I have removed that since then. I have put on a pump and reservoir from a 89 Mighty Max 2.6. Since I don't have A/C I made a bracket and bolted the reservoir to the side of the head near the valve cover. I can try to get pics in the next day or two. I did this cause i didn't like have the reservoir so low. Made it hard to fill.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Power Steering Pump and Reservoir [Re: heathdogg] #1078657 08/04/15 06:43 AM
L
Thanks, my problem is I have AC,
I think I have seen the power steering up you speak of. Pictures would be nice, maybe I can do something similar. I don't want to take it apart until I pass inspection. But I will have to do something about it eventually.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6146 MB (Peak: 0.6859 MB) Data Comp: Off Server Time: 2026-05-25 15:01:06 UTC
