New 03 Monter LS owner. #1078659 08/01/15 09:43 AM
Jp1985 Offline OP
I bought an 03 full size montero ls on the 30th of july. I have been combing and combing classifieds but never found one.
Well one popped up on cl and it was only 3 grand!!! for an 03 ls with 166k, so i called emailed and texted him imminently!! i went test drove it and bought it for 2900.
It was flawless with just a few minor causemetic issues and it even has new tags/plates, and new off road tires.... I know i got a hell of a deal but i am worried why. The only other LS i have seen around here are int he 6-10k range with higher miles.
Its a great vehicle, but has a few issues i am discovering....
It is very slow to start, and runs a little rough when started and idling.
the check engine light popped on and i had it coded and they said it was an 02 sensor.
How hard and expensive are they to fix, and how soon does it need to be done?
The drivers side window is lagging a bit and got stuck on me last night. I waited a while and restarted engine and it rolled up possible electrical issue??
Oh and its missing the cover that covers the third row seat when it goes into the floor.... i don't know the part name or where i can find one but i was hoping someone would know as i really would like to find one.
Re: New 03 Monter LS owner. [Re: Jp1985] #1078660 08/02/15 04:50 PM
lordtrunks Offline
rockauto.com will before friend on cheap replacement parts.
those o/2 sensor are pretty easy to change soak them down pretty good the night before with some PB Blast a few times and again a few minutes before your ready to pull them off and should aid in getting them off easier. Some times they do weld them selves into the exhaust from all the heat cycling going on. Also check to make sure you don't have cracked manifolds the 3.8 mani's crack pretty easy. YOur window could be a couple things the contact on the switch maybe dirty or worn so its not getting good connection or the motor needs replaced being the driver side it could be any of the above start with the cheap and easy which is pulling the switch and trying to clean it i havn't had a gen 3 switch apart but on the gen 1's they have copper contacts that you can solder to fill the gap that gets worn into them from use.
SLow start is more that likly your battery, also do a tune up on it that should clear up the rough idle, along with doing that o/2 sensor.
89 2 dr turbo diesel
89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5910 MB (Peak: 0.6401 MB) Data Comp: Off Server Time: 2026-06-21 19:05:44 UTC
