Page 14 of 14 1 2 … 12 13 14
Re: Montero Sport & Jeep A/T Output Shaft [Re: ES_97Sport] #1104331 05/10/18 07:59 PM
ES_97Sport Offline OP
Things that make you go "Hmmmmm...."
I picked up a spare V4AW3 from a 1998 Sport a couple weeks ago. I just got around to pulling the tail shaft housing a few days ago and found that this transmission already has an output shaft with the outside lock ring groove.
Re: AW4 shifter [Re: ES_97Sport] #1104332 05/11/18 12:33 AM
I think I'm finally done with all the wiring diagrams for the VSS, shifter TCM and transmission & t-case swap. Essentially, this is a LOT of wiring just to make the new setup do the exact same thing the original OEM setup does. smile Only without shift-on-the-fly and this will have full manual shifting when I want it. smile
(PDF that all the images were taken of, below...)
1999 Mitsubishi Montero Sport Limited 3.5L SAS, Transmission and T-case Swap (PDF)
Now, on to building the CAL file for the PCS TCM. smile
PHP: 7.4.33 Page Time: 0.019s Queries: 16 (0.016s) Memory: 0.6060 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-10-24 01:25:24 UTC
