Re: 1st gen Montero buyer's guide/advice? [Re: ryany] #1078733 08/28/15 06:46 PM
Bernoulli Offline
Consider rebuilding the radiator to three core and replacing the water tube that goes from the pump to the rear of the engine.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: 1st gen Montero buyer's guide/advice? [Re: Bernoulli] #1078734 08/29/15 04:58 AM
zarktheshark Offline
Wasn't there a harmonic balancer bolt recall on the v6? I seem to recall something about them breaking.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: 1st gen Montero buyer's guide/advice? [Re: zarktheshark] #1078735 08/29/15 10:24 PM
Bernoulli Offline
There have been at least three versions. They have a tendency to back out. They should be properly torqued.
Re: 1st gen Montero buyer's guide/advice? [Re: mellowvr4] #1078736 08/30/15 04:21 PM
jeepfreek Offline
You have the engine out, so replace the rod and main bearings. You'll hate yourself if the oil pressure drops when it's hot because of worn bearings. You might even consider a new oil pump. My engine had 215,000 miles on it when I pulled it for low oil pressure and burned valves. When I opened it up I found the engine had previously been rebuilt. It failed because the PCV system was plugged solid and the engine sludged up to the point of plugging the oil intake screen and starving the bearings. I'm going to relocate the PCV valve from under the intake plenum to be able to service it easily.
Re: 1st gen Montero buyer's guide/advice? [Re: jeepfreek] #1078737 09/03/15 02:40 PM
mellowvr4 Offline
What do you guys think about the ebay oil pumps? Has anyone had any experience with them? like the ITM brand for example.
Can't stop!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6135 MB (Peak: 0.6944 MB) Data Comp: Off Server Time: 2026-10-24 03:24:48 UTC
