gen 1:: rebuild my 5 speed tranny or covert to 4cyl auto for same ? #1078782 08/11/15 07:18 PM
TresMon Offline OP
Si I need to get my Raider back on the road asap. Should I rebuild my km145 5 speed with a tuf pan or convert it to a 4cyl. Auto tranny for about the same price??
im doing good to get 40k miles out of a km145 but never had a tough pan and never ran Redline MTL 90 weight that is supposed to make brass synchros last way longer........
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: gen 1:: rebuild my 5 speed tranny or covert to 4cyl auto for same ? [Re: TresMon] #1078783 08/12/15 05:46 AM
9
90rustymontero Offline
So, just my 2 cents.... I would switch to the auto transmission. The autos are known to be a lot stronger than the manuals.
1989 Mitsubishi Montero SWB V6, Aisin manual hubs, gen 2 front brakes/rotors, rear LSD, A44DL lock-up transmission, BFG 33's.
Re: gen 1:: rebuild my 5 speed tranny or covert to 4cyl auto for same ? [Re: TresMon] #1078784 08/12/15 03:33 PM
monte Offline
I don't see why on a stock 2.6? With a turbo 2.6 pushing LOTS of power the only thing really wrong was the 5th/overdrive gear always blowing up (I went through 2 of them)
Once I did the "AUTO CONVERSION FROM HELL" (search for my thread) you won't believe how much power is sucked away.
Is it nice? Yeah.. it's a slushbox.. and bulletproof
But you'll want the 5sp back. I promise.
P.S. to convert to auto isn't just peaches and cream <img src="/forums/images/graemlins/lol.gif" alt="" />
1986 SWB Turbo Pajero (aka RedCar). 2" Lift, 33" BFG ATs, Rear locker,Custom 160a Alt, 9000lbs Warn Winch,Con-Ferr Custom built Conferr rack just for RedCar!, Safari Snorkel,3 AGM Deep cycles
1995 SR (Lucky)-SOLD..Kinda sad
Nissan Leaf(Astro), Tesla-S 85kw (Nicoli) & 2014 Rav4EV (Tesla inside)
Re: gen 1:: rebuild my 5 speed tranny or covert to 4cyl auto for same ? [Re: monte] #1078785 08/12/15 06:37 PM
TresMon Offline OP
Thanks so much for the input!
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: gen 1:: rebuild my 5 speed tranny or covert to 4cyl auto for same ? [Re: TresMon] #1078786 08/12/15 07:20 PM
The auto as said is bulletproof. It's basically the same Trans for the V6. Also as said, drains power I guess. Seemed slower getting to speed. Once there, seemed to hold it easier. Inertia I would imagine of the heavier torque converter assembly. Never had an issue with my 5 speed. When I got it, it had 280,000 miles on it, it belonged to a traveling salesman. I put some new GL4 in it, along with a Tuff Pan. Ran 30,000 miles without any issues, using 31's, 32's, and 33's. Still shifted smooth as silk when I gave it to the eldest son, him running 35's.
Re: gen 1:: rebuild my 5 speed tranny or covert to 4cyl auto for same ? [Re: Mudraider] #1078787 08/13/15 05:24 AM
Jason (87Monty) has been working on a hybrid transmission conversion to ditch the KM-145 and it's observed problems. Read through this: Mixtubishi Trans
Re: gen 1:: rebuild my 5 speed tranny or covert to 4cyl auto for same ? [Re: rxinhed] #1078788 08/13/15 06:02 AM
I have had bad experiences with the KM-145 manual. I prefer the KM-148 auto myself. And my daily driver is a 6-speed manual Camaro, so I do like to shift...
Re: gen 1:: rebuild my 5 speed tranny or covert to 4cyl auto for same ? [Re: TresMon] #1078789 08/13/15 04:51 PM
Bernoulli Offline
I've had 7 MMC 4X4s - all manual. I've had two or three transmission rebuilds - primarily #2 synchro. I've never driven a MMC auto, but I much prefer to decide my gear and RPM rather than have an automatic transmission do it.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: gen 1:: rebuild my 5 speed tranny or covert to 4cyl auto for same ? [Re: rxinhed] #1078790 08/16/15 01:31 AM
TresMon Offline OP
Thanks again everyone for the input!
Ended up up I bought the whole monty from the junkyard for $250! Gauges are gone as are the wheels/tires but everything else is there including auto tranny. I won't be able to haul it away until October. So gonna go ahead and build the KM 145 with tuff pan, then have it as a backup tranny when I take possession of the junk yard monty.
Jason: Read through this: Mixtubishi Trans
Will do. Big thanks.
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6284 MB (Peak: 0.7316 MB) Data Comp: Off Server Time: 2026-07-14 11:33:18 UTC
