87 Montero needs a swap #1078791 08/12/15 03:14 AM
chase_carmichael91 Offline OP
Hey everyone I have a 87 Montero Sport with it's original 2.6 gas engine. I would like it to have little more pine there is not to much info on these cars in terms of engine swaps. My question is, is there an engine that is a direct fit and legal in California. If so please respond any info would help .
87 Mitsubishi Montero Sport 2.6 M/T
Re: 87 Montero needs a swap [Re: chase_carmichael91] #1078792 08/12/15 04:37 PM
4G64 2.4 from a mighty max or early Montero Sport if you want more power is what you're looking for, there are diesels too but $$$ they are however the simpler swap.
Re: 87 Montero needs a swap [Re: chase_carmichael91] #1078793 08/12/15 07:25 PM
Answering your question directly, using the 2.4 as Toasty said, along with all of it's EGR stuff, and the 2.4 electronics, will bring a big smile to the government sniffers. Upgrading to FI instead of carb will make an easy inspection. Bonus for you will be better mileage and power, ease of finding issues as you'll be able to plug the ECU into a puter.
Re: 87 Montero needs a swap [Re: chase_carmichael91] #1078794 08/13/15 12:51 AM
ryany Offline
A turbo 2.6 from a Starion/Conquest is a fairly simple swap as well and has been well documented on this site.
95 Montero SR
Re: 87 Montero needs a swap [Re: ryany] #1078795 08/13/15 12:59 AM
Thanks for the info everyone. Also do you rhink the 2.6 turbo would pas smog.... Love me some boost.
Re: 87 Montero needs a swap [Re: chase_carmichael91] #1078796 08/13/15 05:21 AM
Engine bay of my '88 Mighty Max:
California B.A.R. approved and was driven regularly until I chose my Ramcharger for more comfort. The 10-psi was extremely gratifying compared to the NA engine in my '87 Raider.
Re: 87 Montero needs a swap [Re: rxinhed] #1078797 08/13/15 07:12 PM
ryany Offline
The 2.6 turbo obviously was able to pass emissions in the vehicles it originally came in, so there's no reason it wouldn't pass in another vehicle provided you swap over any emissions equipment with it as well. This would apply to any engine you choose to swap into your vehicle.
95 Montero SR
Re: 87 Montero needs a swap [Re: ryany] #1078798 08/14/15 02:50 AM
In Cali it is different you can't put a v8 in a montezy because the 87 style never came with one of the trim packages ome.. Correct me if I'm wrong.
Re: 87 Montero needs a swap [Re: chase_carmichael91] #1078799 08/14/15 03:28 AM
That used to be incorrect. You could swap in newer anything as long as all EGR equipment for the engine was there. We used to talk with a dude from California on doing V8 swaps from Camaros into S-10's. Actually kind of a cool rule I think.
Re: 87 Montero needs a swap [Re: Mudraider] #1078800 08/16/15 05:13 AM
Can anyone get ahold of a front pipe in good condition for the 2.6. Mine is burnt.
PHP: 7.4.33 Page Time: 0.018s Queries: 16 (0.015s) Memory: 0.6368 MB (Peak: 0.7602 MB) Data Comp: Off Server Time: 2026-07-14 07:26:02 UTC
