Going back to 22re. #1078811 08/13/15 07:45 AM
Mrty5 Offline OP
Bought a 1991 Toyota 4wd pick up. The original motor a 22re was replaced with an 80-83 22r. The 22r is dead. I bought another motor that was suppose to be a 89 22r. Well when it arrived it was a 1994 22re. 90% of the original wiring is still in tact plus computer is still in truck. Thinking of going back original. The 22r fuel system was a outside mounted low psi fuel pump. It's mounted on top of fuel tank. Would it be worth putting it back original? Any advice or thoughts would appreciated. Also the place I bought the motor are sending me a carb and intake. The intake of the 80-83 won't bolt to the new motor. I knew I would have to change the exhaust on the truck cause the exhaust is different on the later model 22r.
Re: Going back to 22re. [Re: Mrty5] #1078812 08/25/15 07:35 AM
Snowtoy Offline
It would be worth switching back to efi, if you have all the components, the 22re has more HP, better mpg, starting, etc.
If you do, make sure to use '89-91 injectors, the '92-'95 injectors have a different impedance, and wont work with the '91 ecu.
Re: Going back to 22re. [Re: Snowtoy] #1078813 08/25/15 09:00 AM
Mrty5 Offline OP
I need to buy the injectors from 89 to 91, can u change the ecu?
Re: Going back to 22re. [Re: Mrty5] #1078929 09/11/15 07:15 PM
Snowtoy Offline
Yes, you either need to buy '89-'91 injectors, or put in an ecu for the '94 engine, should be '92-'95(non-Tacoma) ecu. However I am not sure if there are other circuits that the '94 ecu is supposed to have compared to the '91, may through trouble codes that could cause running issues.
This forum is a bit dead, if you need quicker replies, yo might consider joining another forum such as Marlincrawler.com.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6040 MB (Peak: 0.6597 MB) Data Comp: Off Server Time: 2026-11-19 23:57:36 UTC
