Trouble finding the IAC (Idle revving up and down) #1078907 09/10/15 02:50 AM
mfarmer10 Offline OP
So I'm on the hunt to find out why my idle starts revving so high then dies back down. Reading up on this it sounds like the IAC/ ISC could be to blame. Should I take this off and give it a good cleaning or just replace it entirely? Is this what's located underneath the throttle with a large black plug?
3.0 89 raider
Re: Trouble finding the IAC (Idle revving up and down) [Re: mfarmer10] #1078911 09/10/15 02:48 PM
danz91crx Offline
You will find the Factory Service Manual at Mitsubishilinks
The page is setup so you can donate to the host of the FSMs and help with his cost to keep them available.
The IAC is next to the throttle position sensor closer to the firewall.
Is your check engine light on? Do you get the erratic idle at startup or only after the engine warms up? Have you checked your coolant level?
1990 LWB RS A/T
1990 LWB Base A/T
1991 LWB LS A/T Going...Going...
Re: Trouble finding the IAC (Idle revving up and down) [Re: danz91crx] #1078913 09/10/15 04:47 PM
I downloaded the manual and I'm still having troubles finding it. But yes my check engine light is comes on and off. And sometimes it's a bit difficult to start. It will act like its struggling to stay on and then suddenly rev itself pretty high
Re: Trouble finding the IAC (Idle revving up and down) [Re: mfarmer10] #1078915 09/10/15 05:35 PM
danz91crx Offline
Guess I should have looked first. The IAC is under the air intake hose and yeah it has a large black plug. Has the two small coolant lines going to the intake next to it too.
Info on checking your engine codes is in the FSM along with testing methods for the IAC if you want to remove and test it as well.
Recently my idle was temporarily erratic when I was refilling my coolant after doing a system flush. That's why I asked if you checked your coolant level. If the temp sensor is getting bad readings it can effect the idle.
1990 LWB RS A/T
1990 LWB Base A/T
Re: Trouble finding the IAC (Idle revving up and down) [Re: mfarmer10] #1078916 09/10/15 05:44 PM
danz91crx Offline
If you were having any trouble finding info in the FSM you downloaded its in the mpi-system file
1990 LWB RS A/T
1990 LWB Base A/T
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6064 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-06-10 01:45:41 UTC
