Re: Overheating/ High temp
[Re: SgtOso]
#1079133
09/28/15 02:45 AM
Thank you for the info. The temp gauge reads 238* at the highest while driving on the highway and then slowly cools down when the speed drops. Like I said earlier, I don't have any issues when trail riding even on a hot day or driving at surface street speeds. But, I will go to a larger fan.
[Re: SgtOso]
#1079137
09/28/15 02:27 PM
Sarge I would put a timing light on that thing and make a few chalk marks or a timing TAPE on the balancer and run the engine up to see how much timing is in the setup at 2400 rpm. Like I said I had the same problem with an engine that wasn't advancing the timing enough at speed. If your timing is GOOD then I'd put the larger fan on there. 238 is about 20* higher than I'd like to see the temp at speed. Big Jim
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.5932 MB (Peak: 0.6577 MB) Data Comp: Off Server Time: 2026-10-21 17:31:31 UTCValid HTML 5 and Valid CSS
