Where to hook up to pull motor. #1079077 09/22/15 02:05 AM
Mudraider Offline OP
I'm pulling the motor in my 89 V6 SWB this weekend. Going through the FSM,and Mitsubishi has a really crappy drawing of where to hook up the chains from my cherry picker. I see where they want you to hook up the drivers side, but I have no idea where they are saying to connect the passenger side. Nothing substantial really visible on that side.
Don't really care for the connection on the driver's side, contemplating just wrapping axle straps around the exhaust manifolds and going from there. Something I'm missing?
Re: Where to hook up to pull motor. [Re: Mudraider] #1079078 09/22/15 02:19 AM
RaiderMonteroFL Offline
You swapping out for a different motor or rebuilding that one Frank?
Re: Where to hook up to pull motor. [Re: Mudraider] #1079083 09/22/15 08:50 AM
Just freshening it up while I'm putting a clutch in it.
Re: Where to hook up to pull motor. [Re: Mudraider] #1079091 09/22/15 10:33 PM
Maciek Offline
I'd try to find some sturdy bolt holes, but if You're not taking the manifolds etc. off I suppose the pickings might be slim (4 banger here).
'88 Raider - 250+K | 2.6L G54B; no balance shafts, non jet-valve head, ARP head studs| Weber 32/36 DFEV | Pacesetter 4>1 | 2 1/4" magnaflow | 32" BFG A/T | 2" bar crank & add-a-leaf | +2 SkyJackers | bumpstop del | Optima Yellow-Top | Curt GenII receiver
Re: Where to hook up to pull motor. [Re: Maciek] #1079116 09/24/15 02:37 PM
tdf46 Offline
Under the back end of the right side exhaust manifold there is a bracket with a slot for a hook or run a bolt with washers through the slot. Most easily seen from underneight.
Re: Where to hook up to pull motor. [Re: Mudraider] #1079122 09/26/15 01:55 AM
That would explain the crappy pic in the FSM. I will go fishing with my hands
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6104 MB (Peak: 0.6805 MB) Data Comp: Off Server Time: 2026-10-22 12:13:04 UTC
