anyone have pics of stock oil cooler set up? #1079201 10/05/15 02:53 AM
Mudraider Offline OP
Reading thru through the FSM and just realized the PO had the oil cooler deleted and a hose loop installed. While mine's apart, would appreciate some pics of how it's run. The FSM drawings sucking for that kind of thing.
Re: anyone have pics of stock oil cooler set up? [Re: Mudraider] #1079204 10/05/15 05:24 AM
mynion Offline
I somehow doubt my 94 sr oil cooler pics will help, but if they will I will be glad to post
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
Re: anyone have pics of stock oil cooler set up? [Re: Mudraider] #1079210 10/05/15 10:49 PM
Ah crap, thanks. 89 SWB 3.0
Re: anyone have pics of stock oil cooler set up? [Re: Mudraider] #1079218 10/06/15 04:02 PM
danz91crx Offline
The lines are mounted to the body under the air filter when they go from rubber to metal off the filter bracket
Through a hole in front
To the oil cooler mounted horizontally behind the grill
The upper line on the filter bracket goes to the lower point of the cooler
1990 LWB RS A/T
1990 LWB Base A/T
1991 LWB LS A/T Going...Going...
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6007 MB (Peak: 0.6562 MB) Data Comp: Off Server Time: 2026-07-14 10:49:54 UTC
