Bought a 91 Montero RS #1079331 10/20/15 01:50 AM
Dartmouthbrian Offline OP
So I was on here a year or so ago, posted a few times and then disappeared on my hunt for Montero.
It has taken over a year, but the search is over. I bought a green 91 RS. It has high miles, but it was not beaten all to hell off road. I got it on Friday. I've changed the oil, flushed the radiator, greased the chassis.
Any other things you all can think of? A few things I've noticed. I think the throttle body needs a good cleaning. I have so low idle 400-500 when stopped and in drive.
Any how thought I'd share! Cheers [img:center][/img]
91 Montero RS
90 Montero base
Re: Bought a 91 Montero RS [Re: Dartmouthbrian] #1079338 10/21/15 02:50 AM
You're pic didn't show up, but glad you found one. Unless you have the full maintenance records, I'd figure that whole timing belt, water pump, crank bolt stuff that is on here a lot.
Re: Bought a 91 Montero RS [Re: Dartmouthbrian] #1079339 10/21/15 02:52 AM
Probly be a good idea to look up the FSM for it at mitsubishilinks.com and do one of the major services.
Re: Bought a 91 Montero RS [Re: Dartmouthbrian] #1079341 10/21/15 05:36 AM
Thanks all... Quick question, on the mitsubishi links website, I don't see a FSM for 1991. Is the 1989 the same?
91 Montero RS
90 Montero base
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5998 MB (Peak: 0.6558 MB) Data Comp: Off Server Time: 2026-07-13 15:47:15 UTC
