Procedure for shifting in and out of 4x4? #1079343 10/21/15 01:09 PM
Max76 Offline OP
I am a recent owner of a 1990, v6, automatic, with automatic hubs.
What's the procedure for shifting in and out of 4x4? Vehicle standing still? Do you have to back up to go back to into 2wd?
If someone could share the protocol I'd be very appreciative. Thanks.
Re: Procedure for shifting in and out of 4x4? [Re: Max76] #1079344 10/21/15 05:55 PM
4x4Wire Offline
In general, the procedure should be:
Stopped
Shift transmission into neutral
Shift transfer case into high or low range
To get out of 4x4, same process...
except, shift the transfer case into neutral.
As always, there are exceptions due to variations in transfer case styles and whether you have floor shift lever or dash mounted switch.
Regardless, the basic process is the same.
WRT to hubs, with manual locking hubs, it is a good idea to backup a few feet after unlocking the hubs to ensure the lock does fully disengage.
It is generally not an issue with auto-locking hubs.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Procedure for shifting in and out of 4x4? [Re: Max76] #1079345 10/21/15 06:03 PM
cheesegrater Offline
My '89 owner's manual says...For 2H to 4H, Automatic transmission
1. If vehicle is moving, bring to complete stop.
2. Set the transfer case shift lever to the 4H position.
Re: Procedure for shifting in and out of 4x4? [Re: cheesegrater] #1079346 10/21/15 06:51 PM
Max76 Offline OP
Thank you gentlemen.
Can you shift from 2H to 4H and back with the vehicle off?
Re: Procedure for shifting in and out of 4x4? [Re: Max76] #1079347 10/21/15 10:44 PM
Yes. I'd like to add that you can DISengage 4WD while moving, but to disengage the auto hubs you have to stop and back up about ten feet.
Re: Procedure for shifting in and out of 4x4? [Re: Max76] #1079348 10/21/15 11:46 PM
4x4Wire Offline
That is more of a vehicle specific issue. If you have a mechanical linkage, yes. Some vehicle (especially auto transmission) depend on a vacuum or electric impulse to accomplish the shifting.
John Stewart
Editor - 4x4Voice
Re: Procedure for shifting in and out of 4x4? [Re: Max76] #1079367 10/23/15 04:47 PM
Yes you can shift from 2h TO 4h with the vehicle off or on since it's a purely mechanical system for that drive change.
Re: Procedure for shifting in and out of 4x4? [Re: Max76] #1079377 10/24/15 01:26 PM
JAVYPRO Offline
You can shift on the fly ONLY after stopping and engaging 4H, THEN with the vehicle in motion you can shift on the fly 4H<->2H with no problem THIS ONLY BETWEEN 2H AND 4H NOT 4L. You have to stop to shift to 4L.
To disengage, place on 2H and back up for about 6 feet.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6209 MB (Peak: 0.7195 MB) Data Comp: Off Server Time: 2026-07-13 19:52:45 UTC
