Bubba,
I have the exact same truck. It is not what you think it is. I went through this this summer. Your head gasket isn't blown, YET! Unless of course you have coolant in the oil and white smoke out the tail pipe.
There is a coolant pipe that runs down the v-channel from the back of the water pump out to the back of the engine and up. It cannot be seen without the plenum and the manifold off. There's an o-ring that seals the joint between the water pump housing and the pipe. It goes bad and causes coolant to leak into the v. From there, the coolant burns off and will never be seen as a drip, a leak, a waterfall... Nothing. Completely hidden. I was going to take my truck across the country until i found this out, from a confirmed positive for combustion fumes block test. (That's when I hopped in my 87 4 banger and drive that! But that's besides the point)
So the coolant just keeps disappearing. You'll drive on the highway fine and then you'll get off or slow down, or come to a stop and it'll rise. You'll see there's no more coolant, and then you add more. And the cycle keeps repeating.
Don't drive it anymore if you want to keep it alive. Have the head gaskets replaced, the o ring for the pipe replaced, and the water pump and timin belt changed. I did it for 600 bucks this summer and the truck has never run better. Cool as a cucumber. I'd be happy to pm you pics. Just let me know.
'90 V6 SWB, General Grabbers, Rigid D2s, wicked strong '87 SWB 4 banger, 5 speed, General tires, a work in progress. Monty and Mav, Monteros - Strong like Bull
