need good distributor 3.0 1989 #1079751 12/23/15 09:10 PM
bearingman Offline OP
looking for good distributor for 89 3.0. OR ideas why it won't start. I just had engine swapped and newer engine had a dist that would not plug into my wiring harness. Guy says he changed the coil and ICM, but won't start. He says fire is going out of coil, but not thru dist. Charlie (Old Colt) thinks he may have timing off 180. Any other ideas? Dist was working when the bottom end went.
Re: need good distributor 3.0 1989 [Re: bearingman] #1079753 12/24/15 12:41 AM
crank angle sensor???? Available seperate?
Re: need good distributor 3.0 1989 [Re: bearingman] #1079771 12/30/15 09:54 PM
:)turns out it was just a wire in harness. Got it straight. :mad: :cry: but the crank/bearings are bad. moves in place about 1/16"
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5911 MB (Peak: 0.6442 MB) Data Comp: Off Server Time: 2026-07-14 10:49:49 UTC
