1994 Montero SR | Crank No Start | Arizona #1079796 01/04/16 07:12 PM
Chris_Harper Offline OP
Hello all, new to 4x4 wire in AZ.
I recently purchased a 94 SR from a 71 year old man under the impression that the vehicle was sitting for 3 years due to fuel pump & it would be an easy fix and i would have a nice $400 montero for exploring... hahaha not the case yet!
It did in fact have a bad fuel pump but the vehicle still will not start. so below if the other steps i have taken.
- Replaced fuel pump, damaged fuel pressure line, & fuel filter.
- Replaced ignition switch as well.
- Engine does have spark, really good spark. pulled (2) front spark plugs that can be reached and they do have fuel on them.
- checked fuel pump relay and its good.
- Timing belt is in tact, not broken.
- The motor cranks but will not start, every few rotations whote smoke comes out of the throttle body but that is it.
Any help or suggestion would be greatly appreciated. My next step is to pull the timing covers and intake to check for other than obvious vacuum leaks etc... I dont understand these motors real well and hoping some of you may have some input on processes i haven't performed yet before tearing it down.
Re: 1994 Montero SR | Crank No Start | Arizona [Re: Chris_Harper] #1079799 01/05/16 01:59 AM
PM inbound
Re: 1994 Montero SR | Crank No Start | Arizona [Re: Chris_Harper] #1079805 01/05/16 05:48 PM
TaylorAuto1 Offline
I had the same problem with a 95 montero rs and it ended up being the ecm.
Re: 1994 Montero SR | Crank No Start | Arizona [Re: Chris_Harper] #1079808 01/05/16 09:27 PM
I found an ECM at a junkyard, may go pick that up as well. but i do have spark which if i understand right shouldnt happen if the ECU is bad. thoughts?
Re: 1994 Montero SR | Crank No Start | Arizona [Re: Chris_Harper] #1079809 01/06/16 12:21 AM
TaylorAuto1 Offline
i had spark but no injector pulse when the ecm went out. I used starting fluid to see i could get it to start which it did start on but that when i fund out i had o injector pulse.
Re: 1994 Montero SR | Crank No Start | Arizona [Re: Chris_Harper] #1079813 01/06/16 02:35 PM
Great diagnostics tools in the Factory Service Manual available here at mitsubishilinks.com
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6108 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-06-22 01:06:30 UTC
