Rebuilt transmission won't shift #1079806 01/05/16 06:10 PM
TaylorAuto1 Offline OP
Ok so I rebuilt a aw30-40le for a custumer. I put it in and it doesn't shift. If I shift it manually it works just fine. I have taken it apart 3 times and went threw it. Still same problem. The only code I get is output speed sensor. I replaced it still same problem. The transmission range selector doesn't work and neither does the od button. Everything in this thing is new accept the hard parts that were reusable. I am ASE master tech and have done 1000s of transmissions. This thing is beating me up. A buddy of mine who works for mitsu told me to try montero sport forum ed over there told me to come over here. I thought i had the problem figured out with the intermittent power to the speed sensor but nope. If anyone could help me shed some light on this it would be great
Re: Rebuilt transmission won't shift [Re: TaylorAuto1] #1079810 01/06/16 01:04 AM
4x4Wire Offline
Search the forum archives as there is a lot of info about transmission issues. The Mitsu, Toyota and Jeep share the basic AW-4 transmission for a lot of application with a few differences. Not sure of the exact configuration of the range selector. If mechanical, perhaps a broken cable??? If electrical???? And, are there any vacuum ports? Just throwing out some ideas....
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Rebuilt transmission won't shift [Re: TaylorAuto1] #1079812 01/06/16 02:31 PM
What's the vehicle?
Re: Rebuilt transmission won't shift [Re: TaylorAuto1] #1079816 01/06/16 04:24 PM
1995 Montero sr
Re: Rebuilt transmission won't shift [Re: TaylorAuto1] #1079830 01/09/16 06:33 PM
Doesn't that have a computer also
Re: Rebuilt transmission won't shift [Re: TaylorAuto1] #1079837 01/11/16 07:23 PM
Yes
Re: Rebuilt transmission won't shift [Re: TaylorAuto1] #1079841 01/11/16 08:24 PM
Sounds like the pulse gear isn't sending signal, it's kind of a picky sensor.
Re: Rebuilt transmission won't shift [Re: TOASTY] #1079893 01/27/16 12:41 AM
Finally figured out the problem. Found 3 issues not exactly sure which one was the issue, but I found 2 wires with the same plug 1 white and 1 black. Well my tech had the white to black and black to white. one is for the trans temp and the other is for ATF lvl. Hooked them up to black to black and white to white. Then Recalibrated tps. Now it shifts on its own.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6226 MB (Peak: 0.7051 MB) Data Comp: Off Server Time: 2026-06-22 06:12:32 UTC
