Re: 87 Montero Rear Disc Brakes Idea
[Re: BlueMont]
#1079879
01/22/16 01:54 AM
If I were you i'd just order the Montero Sport axle from a junkyard, get the one with the locking diff. then you will have disc brakes and an air locker for hundreds of dollars. It's an easy swap, you'll need to drill your pinion flange and clearance the radius for the bolt heads.
There's one in South Bend Indiana for $150 4.63 ratio, you confirm the disc brakes.
Veldman's Auto Parts 1-800-888-3821
[Re: BlueMont]
#1079883
01/22/16 06:32 PM
Thanks that's a great find. I had a deep creek crossing and apparently screwed more up than I thought, so I'll have to wait a bit. I believe I have water in my gas tank now. It wants to die after going around a turn and especially going up a hill. After sitting for a while in the garage, if you start it and let it just run and sit there it seems to run fine.
I think I'm going to drain the tank and maybe put a Holley 5200 with a Weber adapter plate on it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5945 MB (Peak: 0.6488 MB) Data Comp: Off Server Time: 2026-06-07 07:17:28 UTCValid HTML 5 and Valid CSS
