Km145 T-case chain slipping. Questions. #1079907 01/30/16 08:37 PM
TresMon Offline OP
Hey crew,
I'm pretty sure the T-case chain in my gen 1 has slipped on me a time or three now. At first I thought it was a cv joint but now I'm pretty sure it's the chain.
I looked around the net and didn't find a source for a new chain. Anybody know a source or a cross reference part number?
Should I change the sprockets too?
Any other tips tricks or advice before I pull out the T-case and open it up?
As always much thanks & appreciation.
TresMon
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: Km145 T-case chain slipping. Questions. [Re: TresMon] #1079915 01/31/16 04:11 PM
Never hear about issues with the transfer case. Probly going to suck it up at the dealer or get a used transfer case.
Re: Km145 T-case chain slipping. Questions. [Re: TresMon] #1079916 01/31/16 04:14 PM
Mitsubishiparts.net lists the transfer case new. Sit down for this; $3,000. But no chain or sprocket. Only seals.
Re: Km145 T-case chain slipping. Questions. [Re: TresMon] #1079923 02/01/16 03:23 AM
mynion Offline
Sounds like its time to hunt the salvage yards...
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
Re: Km145 T-case chain slipping. Questions. [Re: TresMon] #1079930 02/02/16 04:18 PM
TresMon Offline OP
Thanks for responding fellas.Think it could be worn bearings thats letting it slip?
Any other known components in the driveline that can make popping noises and slip?
Do the cv axle splines ever slip in the diff?
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: Km145 T-case chain slipping. Questions. [Re: TresMon] #1079936 02/03/16 09:22 PM
It's a chain, on sprockets. For it to slip, it must be stretched WAY out, or the sprockets are fried. It's not too hard to get at to see. Take off the driveshafts, and unbolt the rear outer cover, and the chain and sprockets are all right there.
Re: Km145 T-case chain slipping. Questions. [Re: TresMon] #1080052 03/02/16 12:26 AM
TresMon Offline OP
The t-case bearings are shot and the chain is stretched.
Anybody know a source for a chain??
Anybody have a T-Case for a Raider manual tranny that can be bought?
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: Km145 T-case chain slipping. Questions. [Re: TresMon] #1080060 03/02/16 07:33 PM
TresMon Offline OP
I looked in the FSM for a spec on the t-case chain deflection/slack spec. I found none listed. Did I miss it? Anyone know this spec?
Also a Transmission parts supply house told me all the late 80's era D50 trucks have the KM100 T-case bolted to their(different from Raider) tranny, same as the Raider has the KM100 bolted to the KM145. Can anyone confirm this true for me?
Thanks!
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: Km145 T-case chain slipping. Questions. [Re: TresMon] #1080088 03/07/16 08:04 PM
Trucks had a torqueflyte 3spd a/t until 86. 87 and later had 4spd a/t. All tcases the same excpet maybe input gear
Re: Km145 T-case chain slipping. Questions. [Re: fasteddy] #1080134 03/19/16 05:42 AM
Oso Offline
I've got a spare gen 1 transfer case.... make me an offer + shipping.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6421 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-07-17 05:01:27 UTC
